Help / Advice with ECU failue
I put a OBDII scanner on it and got code P0601 Internal Control Module Memory Check Sum Malfunction.
When I googled P0601 I found next to nothing related to C6 corvettes. Based on some of the things I did read, I tried the following.
- Downloaded the wiring diagrams and tested for high resistance at 13ea ground points.
- Did a full charge on the battery, had it load tested and checked for bad cells.
- Checked every fuse under the passenger floorboard and at the under hood fuse block.
- Checked for damaged or melted wiring under hood, it has headers but they have been on the car for two years.
- Took it to my tuner (who hasn't touched it in two years) and he said he has never seen that problem before, but he believed the ECU was bad.
Today I received an email from them:
I was not expecting that to be the outcome, so at this point I am not sure what to do next. I am nervous about just buying another ECU and towing it to be reprogrammed without knowing why this one failed or what caused it to fail.
I could take it to a dealer, but I would like to control the cost of this if at all possible, my fear is this could escalate quickly.
I have owned the car for 7 years/40k miles and never had a single problem with it. The only mods to the engine are a CAI, ported throttle body, headers and dyno tune. Before I sent out the computer the CEL would reset and I could drive the car for a couple days or a couple minutes before the engine would shut down again, the CEL would come back and the problem would continue until the battery was disconnected/reconnected. It has no other issues that I am aware of.
I'm open to any ideas or suggestions, the warm weather is here and I want to drive it.
Put your "bad" ecu into the car and get it to the dealer. Swap the "new" ecu in and pay for them to flash it with the VIN.
Get the car to your tuner to have him flash the tune on, which hopefully he still has saved.
I would think thats about the cheapest outcome. It seems you need a new ECU, its how you get there now that matters.
Thanks for the feedback, I agree with all of this and it will be most likely what I do.
I was mostly looking for feedback on if there was something else I should look at, check, test etc. before I do what you suggested.
It just seems odd the "main chip" would fail without any external influence or related component failure.
