Magnetic Shock Problem?
Old Jun 1, 2016 | 12:14 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Not junk both show cars. Grow up if you can,t take contrevery. Most posts are on the select drive and elecrical problems and that is one. Have a nice day
Old Jun 1, 2016 | 01:06 AM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default Select ride
Originally Posted by HOXXOH
132K on my OEM F55 DD and I'll watch your Z51 fade in the mirror on rough mountain roads. Then again, all roads in FL are flat, so you've never had a chance to know the difference.
BTW, F55 wasn't available until '04 and it's far different than F45.
MY OPINION. NEVER HAD ANY LUCK SELECT DRIVE BOTH CARS HANDLE LITTLE ROUGH AND THE Z51 WILL OUT FLAT TAKE IT ON TURNS IT ON A Z51 PADLE SHIFT. NO COOLING HEAT UPS LIKE POWER STEERING AND SO ON IT CAN GO FLAT OUT. SUSPENSION UNREAL. THEY ARE RACE CARS,. I ALSO HAVE A Z06 C6 CLOSE CALL. IT IS FLAT HERE BUT I DROVE IN CLOVIS NEW MEXICO. I LIKE THESE DEBATES. GREAT CARS. THANKS JOE
Old Jun 1, 2016 | 04:21 AM
gsflyer2011's Avatar
gsflyer2011
I guess some are missing the point. The OP suspected a problem with the mag ride, not that he had one. Clunking in the rear can be caused by many things, unless shock mounts are loose, rarely by bad shocks mag ride or not. In my opinion he does not. Side note, having had the first mag ride ever in my 89 C4 and now my 11 GS, i love it. For me it is money well spent, a car with two personalities.
Old Jun 1, 2016 | 05:59 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default Select ride
YOU ARE CORRECT . LETS GET TO THE REAL ISSUE. EVERYBODY HAS GOOD AND BAD ABOUT THE SYSTEM. LETS ADDRESS THE REAL PROBLEM. JOE
Old Jun 1, 2016 | 07:38 PM
CSIXVET's Avatar
CSIXVET
Default Problem Found & Solved
A very loose nut on a front anti-sway bar end link was found and corrected, curing the problem.
For preventive maintenance, I plan to replace all four end links shortly.
BTW, after riding in friends cars with low profile tires and enduring a rough ride, I am convinced of the value of the magnetic control system on the Corvette.
Thanks for the comments from Forum members trying to help.
Old Jun 3, 2016 | 05:16 PM
dr_gallup's Avatar
dr_gallup
philly joe - Where is the ignore function on this forum?
Old Jun 3, 2016 | 07:39 PM
cclive's Avatar
cclive
Most people know that on the internet, CAPITALIZING words is meant to convey shouting, right?...
Old Jun 3, 2016 | 10:17 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
what??????
