Edelbrock eforce coolant
https://www.corvetteforum.com/forums...n-nitrous-123/
If you are sure that your not going to get the car in temps below freezing, then you can run just distilled water with water wetter only isntead.
Note, it's a lot easier/cheaper to just mix up 3 gallons of 50/50 Dexcool with 12 oz of water wetter, since you use the same mix in both the radiator fluid, and the S/C inter cooler fluid supply as well. Hence can have a gallon of the mix with a gallon of DIY 50/50 meth mix in the back cubby storage in the back if you need to top either system off.
http://www.redlineoil.com/Products.aspx?pcid=10
As for coolant, Edelbrock states in the install manual to use the same coolant that the engine will use, which is 50/50 Dexcool in the vet. If the installer used 50/50 Dexcool (should be light orange) is still up in the air isntead. Hence if the coolant is Green, then drain the system to get it out, do a quick flush with distilled water, then fill the system back up with the 50/50 Dexcool with water wetter isntead.
Simply, do not mix the standard Green antifreeze with orange Dex cool, and never use the standard Green anti free in the Vet radiator system!!!
