I have some LS3 length injectors that I need adapted to LS2 length. Where can I buy adapters that mount from the top of the injector? I prefer that style instead.
You only want an adapter that sits on top of the injector. Anything on the bottom affects the spray pattern.
Injector dynamics and FIC sell them. I can't give you the link because they aren't a vendor, but if you go to one of their sites look under " Height adapters and conversion kits".
Originally Posted by timd38
Call me dumb, who makes the top mounts? I got the FAST ones with the intake.
I can just change them out and not need to get a tune, correct?
Well that really depends. If the adapters on the bottom really messed up the spray pattern you may have some wall wetting issues that need to be addressed if you are using Deka injectors. If you are using factory GM 42lbs LS3/7 injectors than no, those have a very straight pencil spray patterns and you should be ok. Unless you are using drilled injectors, then you just kind of SOL.
