Bought some C6 Z06 calipers from a fellow here on the CF and when I went to mount them I could not get a bolt to thread through the bolt hole. Mind you, at that time, the hole that was involved was one of the two on the left and it wasn't until I looked at all 8 did I realize the extent of the mess I had purchased.
I pressed these out of two of the calipers (came out fairly easily). Does anyone know:
1: what they are called?
2: if the threads are metric or SAE?
3: where one might purchase them?
As always, you guys have all the experience that is much appreciated.
Nick
BTW, I did a search and came up with nothing...
Yep, nice mess, and why you want to wire brush off all the old Blue loctite off the M14x2x47 bolts before you re-install the bolts with Fresh blue loctite (242) isntead.
To bad your not local, or I could just machine you up a new set in SS in a few mins and heat treat/temper them instead.
Check around with your local group, and anyone with a lathe and mill should be able to make you new inserts as well. Hence, its faster to just make new ones, then it is to hexi-coil the old ones isntead.
Note, run a tap through them (14x2) and see just how well the threads clean up. Although the bolts are torqued to 125ftlbs, if its just a spot or two in the thread over all that is a problem with a small section of tooth missing, should still work since the bolt does get close to a full embed over all, and it's the 242 that will hold them in place once it dries.
So you guys know about making assumptions, well, those shavings like pieces of thread we not metal - they were the remains of Loctite. Pull a piece out of there and it crumbled.
Pulled out a small round wire brush, some WD40 and the original nut that I tried to use for the mockup, and lo and behold, all 8 of them came clean.
Live and learn - maybe this will help someone else searching around...
Many thanks,
Nick
This is why I said if, if they were mine it would have been metal, because that would be my luck.
Actually, the "if" was what cause me to eventually head out to the shop and check the reality. Originally, I was fearful of stripping the thread by trying to force the bolts I was using to make their way through, so I had to back off.
It is good shop practice to thoroughly cleaned disassembled components before reassembly to prevent mishap.
In this day and age, USPS's small Flat Rate Box is less than $6 - even for us here in Hawaii. If....you are so willing to "^^^" - whats $6 more!? By the way, what type of SS and what HRc you would use for this application?
From a Machinist's/ToolMaker's stands point, not a good practice simply to "run a tap" just to "see how well the threads clean up"! Tap use for such an occasion can not be just any tap, a "chaser" tap is an appropriate specially designed for chasing/cleaning without removing materials. But most people don't have correct chaser tap laying around.
Another point, inter relationship between fastener/component when tighten, the predetermined stretch under specified torque, induced stretch tension is what held the assembled fastener/component together - not Loctite 242. Once threaded portion on a fastener is damaged.....whether damage is associated with brake system or any other - engineered integrity is compromised just the same...but do or believe what you want....
Yeah, kind of embarrassing - mostly because I couldn't be sure the bolt I was using was the correct bolt.
But re the above, if that's the case, what's the point of using Loctite?
welp... nevermind I just realized what actually happened. It's not stripped, the damn thing turned in the caliper and the flat they machine on it actually cut the material away from the caliper itself. So now the bolt and threaded spacer just turn.
looks like I should start shopping for a caliper.... FUUUUUU
You could always drill a hole or two into the side/space between the two and then force a pin or two into the holes...
one of mine did the same thing. I will catch hell when its time to remove it.
the only way I can see to remove to caliper is cut the bolt head off and slide the rotor and caliper off as a pair. Or somehow pin the bushing while the it's still on the car and see if I can get the loctite to bust loose.
neither sounds like fun. And I'm guessing the bushing is still screwed up.
I know this is a super old thread but i need these inserts, the powder coat company threw mine out by mistake and they are impossible to find anywhere. I would be more than willing to pay handsomely if you were able to make me a set of these. Please PM me it wouldn’t let me send you a direct message.
