Problems with ATI pulley
Old Jul 8, 2016 | 09:32 AM
nurburg's Avatar
nurburg
7th Gear
Default Problems with ATI pulley
I am in the process of installing an ATI 917246 and noticed that the hub is going in not straight, I don't know why could be this...
Has anyone installed a pulley and seen if it comes in easy and well?
Thanks.
Diego
Old Jul 8, 2016 | 09:17 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Put some calipers on the snout of your crank and on the inside of the hub and report the difference.
For what it's worth, when I installed my ati pulley I installed the hub by itself after putting it in boiling water with some antiseize on the crank snout. It was a pretty tight fit (and should be because it's a press fit).
Old Sep 24, 2016 | 11:27 AM
Whis9's Avatar
Whis9
Boiling water here also
no issues
Old Sep 25, 2016 | 10:06 PM
SlowBusa08's Avatar
SlowBusa08
how far on the crank is it??? it's a press fit, so it can't really go on crooked.
To Problems with ATI pulley
