external fuel pump
Old Jul 13, 2016 | 07:41 PM
travis1746's Avatar
travis1746
Default external fuel pump
I'm building a relay to control my external fuel pump to run at key on instead of only running under boost. What circuit should I use to control the relay to turn the pump on? Would any switched 12v circuit work or should I only use the gray wire coming off the stock fuel pump relay. Thanks.
Old Jul 13, 2016 | 09:42 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I'd just use an add a circuit off the fuel pump fuse. Run to relay, use relay to power second pump
Old Jul 15, 2016 | 02:19 AM
travis1746's Avatar
travis1746
Got it all sorted out, thanks for the advice.
To external fuel pump
