question on TPSM?
Old Jul 15, 2016 | 08:23 AM
mazzerman's Avatar
mazzerman
Default question on TPSM?
Hi guys, got the SERVICE TIRE MONITOR on the DIC so checked tire pressures on DIC and right rear says XXX so i'm guessing the battery has gone or sensor is bad (2005 so probably original battery)
So got the TPSM reset tool out and started at front left....No response from sensor,then went round all other sensors and got responses.
So slightly confused.....error was right rear but no response from left front.
Question is.....is it possible that someone has previously programmed the sensors wrongly not knowing the order of programming, and that the TPSM thinks the right front is the right rear?
And second question is i have no idea which sensor is in the tire with it being an import into europe, is it possible its on a different frequency? I cant see all the sensors being swapped out when it was imported.
Is there a way to know what replacements to get or can they be mix n matched?
Cheers
Old Jul 15, 2016 | 08:31 AM
extrapilot's Avatar
extrapilot
OEM batteries are generally good for 8 to 10 years, so I think you need replacement of all of them.
Factory code UJ9 for domestic Corvettes, UH3 for export. Code can be determined by looking inside your C6 Corvette's glove box.
Old Jul 15, 2016 | 10:56 AM
mazzerman's Avatar
mazzerman
Just checked the glove box and some idiot has removed the info sticker
Is it possible to get a build sheet from the VIN anywhere online?
Old Jul 15, 2016 | 12:54 PM
extrapilot's Avatar
extrapilot
My have to get in touch with GM on that one..others here may know for certain.
Don't think the VIN will help with a internet search.
Old Jul 15, 2016 | 01:41 PM
mazzerman's Avatar
mazzerman
I went here http://www.compnine.com/vid.php?vin=
and got a build sheet which gives me all my RPO codes
Cheers
Old Jul 15, 2016 | 02:19 PM
extrapilot's Avatar
extrapilot
Cheers
That's cool, how much did it cost you?
I will have to recommend this site if it worked for you. Thanks..
Old Jul 15, 2016 | 02:24 PM
mazzerman's Avatar
mazzerman
You can get as many as you want for a monthly fee but i just went for a one off fee of $5 which is all i needed.very reasonable
Old Jul 15, 2016 | 03:18 PM
jrose7004's Avatar
jrose7004
You can get a build sheet and window sticker from the Corvette Museum. www.corvettemuseum.com
Old Jul 16, 2016 | 04:02 AM
mazzerman's Avatar
mazzerman
You can, but they are $75
a bit too much for what i wanted it for, got the info i needed for $5
But thanks for the reply, most appreciated.
To question on TPSM?
