AC question
Old Jul 15, 2016 | 08:15 PM
jazzmk1's Avatar
jazzmk1
Default AC question
I'll make this short and sweet. My AC shuts off when car is not moving. The fan inside the car still running.....WTF...???
Old Jul 15, 2016 | 08:43 PM
jrose7004's Avatar
jrose7004
Normally that means the compressor has gone bad whenever I've had a car that's done that.
Old Jul 15, 2016 | 08:47 PM
jazzmk1's Avatar
jazzmk1
Default Ac
I just did a check to see if the clutch engaged on the compressor not at idle. Belts are new and tight
Old Jul 15, 2016 | 08:54 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Could be a couple of things
1. Low on charge. Engine speed drops at idle thus compressor slows and pressure drops causing compressor to disengage.
2. Cooling fans have crapped out. Once you start moving you get airflow across the condensor and the system starts working.
Reason inadequate airflow causes the compressor to stop is because the Hi side pressure increases to the limit switch trip point which cuts power to the compressor clutch.
Oversimplified
Old Jul 15, 2016 | 09:05 PM
jazzmk1's Avatar
jazzmk1
Default Ac
Here's a kicker, I just pulled and cleaned the fuses and relay for the ac blowing cold at idle now..???? Will give it a couple of days to see what happens next. The for all the advice for now...lol the fan is working fine
Old Jul 15, 2016 | 10:19 PM
mrk1957's Avatar
mrk1957
Low on charge
Old Jul 15, 2016 | 10:24 PM
LowRyter's Avatar
LowRyter
engine was probably getting hot and air con was disengaged.
or it could be that idle speed doesn't generate enough RPMs to get a lot of cool air.
you didn't mention if the air works when your're moving and maintains a cool temp.
Old Jul 15, 2016 | 11:22 PM
User Omega's Avatar
User Omega
I will agree with the above.
It is either low on charge or is running high discharge due to poor airflow across the condenser. Could be a few things cause that.
To AC question
