so i dropped my mufflers off my supercharged 05 and when driving to the muffler shop to get a quote on straight pipes i noticed it wasnt as quick as it usually is. Is this due to back pressure? will the back pressure issues be solved when i put the straight pipes on or will i need to retune to adjust for the back pressure? Thanks in advance!
C4 of Year Winner (performance mods) 2019
Wow, that has to be insanely bad drone when driving the car with no rear exhaust section. Anyway, I would guess that your tune is going to be off with no rear exhaust (especially if you were tuned with stock mufflers), and personally I would not be going WOT with it in that state. You could potentially be moving enough extra air that it's causing a lean state, which could lead to detonation/knock, which would lead to timing being retarded. Detonation on a forced induction motor is really bad, and should be avoided if at all possible. Another possibility is that running without the rear exhaust is causing enough noise/vibration to fool the knock sensor into thinking their is detonation, and again retarding timing.
It wasnt terrible except for at low rpm when coming to a stop. So once i get the axle back replacment for the mufflers in i should retune? is this why the car felt sluggish? do you think i should continue with the muffler delete or keep the magnaflow mufflers that are on now and just go with a long tube + offroad x-pipe set up?
Mufflers alone should really make enough difference to need a retune. Getting rid of the mufflers completely for straight pipes may make enough difference to need an update. Going from stock manifolds to long tubes will definitely require an updated tune. If you're after power, mufflers to straight pipes is going to be less than stock manifolds to long tubes, especially on an 05 (LS2). If you can find a set of LS7 exhaust manifolds, they will flow a lot better than the LS2/3 manifolds for not a lot of money.
interesting that you say that because i am getting a set of LS7 longtubes off of a 2006 Z that is being returned to stock so this will work out perfectly! i guess ill be waiting to muffler delete until i have everything so i only have to tune it once
I'm at 672RWHP on a bone stock LS3 with LS7 exhaust manifolds and 11psi on a V3 Si. The LS7 manifolds flow really well, and I'm happy with them. Could I gain another 20HP? Probably, but it's not worth the cost differential.
oh very nice, im sitting at about 600 to the crank right now bone stock with the blower around 8psi, im looking to get around 600-650 to the wheels
I gained 14HP from the LS7 manifolds when I was bone stock. Let me know what you gain when you put them on, would be nice to see how much they add to a blown car. 650RW should be fairly easy, do the LS7 manifolds, move one pulley size smaller on the blower for about 10-11psi and add methanol injection.
