C6 base tach wire lead
Old Jul 19, 2016 | 03:52 PM
UmX's Avatar
UmX
Default C6 base tach wire lead
I have searched up and down I can't seem to find the tach wire for my shift left. I even have the cluster out. Read some where a white wire I see no white wire. Looking for asstiance thanks
Old Jul 19, 2016 | 09:18 PM
UmX's Avatar
UmX
I have the launch control in the car lnc2000. Can I grab tac from that?
Old Jul 20, 2016 | 10:55 AM
KENS80V's Avatar
KENS80V
If you have the cluster out then look at the gray connector. Pin #5 is the white wire for engine speed. It is the only complete white wire to that connector.
The gray connector is located at the back of the cluster next to the black connector.
Old Jul 20, 2016 | 11:10 AM
UmX's Avatar
UmX
Ya i had that out and i did not see a pure white one .. lets say not as white as other white wires in the car.. ill snap a pic next time ( later today ) i even tapped into the one i thought was could be the white.. left the car in neutral set the shift light to 2k and revved no dice.
Old Jul 20, 2016 | 11:38 AM
KENS80V's Avatar
KENS80V
Pin 1-black
Pin 2-not used
Pin 3-red/whit
Pin 4-not used
Pin 5-white
Pin 6-dark green/white
Pin 7-brown
Pin 8-tan/white
It's a 16 pin connector. I listed the complete first row.
Old Jul 20, 2016 | 11:41 AM
UmX's Avatar
UmX
Pin 1-black
Pin 2-not used
Pin 3-red/whit
Pin 4-not used
Pin 5-white
Pin 7-brown
Pin 8-tan/white
cool ill remove it today again and take a look.. are you familiar with the raptor lights. If i set it to 2k rpms and rev it, it should light up correct lol
Old Jul 20, 2016 | 11:46 AM
KENS80V's Avatar
KENS80V
The white wire also is split to the HUD module. Pin #4 on the HUD module is the engine speed signal. It is also the only pure white wire at the connector.
Old Jul 20, 2016 | 11:51 AM
UmX's Avatar
UmX
i found this image..
http://imgur.com/U9I4aaE
thats the wire i tried and when i tried reving it to the setting on the light it didnt flash.
Old Jul 20, 2016 | 12:08 PM
KENS80V's Avatar
KENS80V
Yes that image shows the correct wire to tap into.
Perhaps there are dip switches that need to be set correctly on the shift light.
Old Jul 20, 2016 | 12:14 PM
KENS80V's Avatar
KENS80V
Set the Raptor dip switches to the 1/2 ppr if the 2ppr setting didn't work.
Old Jul 20, 2016 | 12:25 PM
UmX's Avatar
UmX
kk ill try that. and see.. thanks for the help and ill let u know what comes from this today
Old Jul 20, 2016 | 01:08 PM
KENS80V's Avatar
KENS80V
I did a search to see how other C6 owners set the dip switches. The setting is:
2ppm. (4 cylinder mode)
one-off
two-on
three-off
Old Jul 20, 2016 | 01:11 PM
UmX's Avatar
UmX
2ppm.
one-off
two-on
three-off
Yea thats how i have it set right now. ill try again thou.. maybe didnt have a solid connection or something
Old Jul 20, 2016 | 01:13 PM
KENS80V's Avatar
KENS80V
OFF is down and ON is up for the dip switches.
Old Jul 20, 2016 | 01:14 PM
UmX's Avatar
UmX
yea
i used this..
https://cdn.shopify.com/s/files/1/02...66487979451693
Old Jul 20, 2016 | 02:56 PM
timd38's Avatar
timd38
I used an Autometer and the white wire as described and it work fine.
Old Jul 20, 2016 | 03:00 PM
UmX's Avatar
UmX
http://imgur.com/a/XPIuA
To C6 base tach wire lead
Old Jul 20, 2016 | 03:03 PM
UmX's Avatar
UmX
here is my rpm harness and hud
http://imgur.com/a/1esZZ
http://imgur.com/a/yb49p
Old Jul 21, 2016 | 08:05 AM
UmX's Avatar
UmX
got it working last night.. thanks for the help. must of been bc it wasnt set into 4cy mode.. off to figure out why my line lock wont work now =/
Old Jul 21, 2016 | 12:11 PM
Buzartiano's Avatar
Buzartiano
Tttt
