Another charging system warning
Old Aug 1, 2016 | 03:43 PM
ShaWING66's Avatar
ShaWING66
Default Another charging system warning
Hi all, my car has joined the club. Before you respond, i do not have NKG plugs and the battery is 3 months old. I have auto lite xp5245 that are probably 10k miles old and for the most part the car runs great. Occasionally I'll get a service charging system error while at the track but last week at dominion raceway I would get 2-3 notifications per lap and the volts would drop to 10.5-12. I made it home without incident on the hour drive home and never had a problem starting the car. This weekend I was working on my car (other things) and the volts were back to normal (14ish). I have long tube headers... Does that create extra heat that could damage the alternator or connections to it? Thanks for your help!
Old Aug 1, 2016 | 05:29 PM
EVRose's Avatar
EVRose
The headers do create extra heat but it's the connection at the starter solenoid that takes a beating. Check to see if it's cracking up and loose there.
Old Aug 1, 2016 | 09:32 PM
WW7's Avatar
WW7
You need to check the voltage at the alternator to see how much it's putting out, check both hot and cold...If the alternator isn't putting out at least mid to high 13s at hot idle it may be bad....WW
Old Aug 2, 2016 | 06:03 AM
extrapilot's Avatar
extrapilot
Add to this is while checking voltage at the back of the alternator, then check the positive battery post, should be only a drop of ~0.4 volts due to resistance in the wiring.
I remember that while checking my car when I changed the battery, voltage at the alternator post was showing about 14.4 with no load on the system.
Old Aug 2, 2016 | 08:02 AM
double06's Avatar
double06
Default Can not remember.....
Was there something about not running iridium plugs and charging or did the non iridiums do something else (ie engine code on some)?
Old Aug 2, 2016 | 12:25 PM
C6topless's Avatar
C6topless
SOunds to me like your alternator is on the way out. You need to get your alternator LOAD tested -- it sounds like it is failing when under stress.
Old Aug 2, 2016 | 01:17 PM
Dano523's Avatar
Dano523
Car idling, and A/C off
Alternator voltage from it back terminal under the rubber boot, to the body of the alternator as the ground point, should be 14.6 volts.
At the battery terminals themselves, should be 14.5 volts.
From the engine fuse block terminal, to the body of the alternator as the ground point, should be 14.5 volts.
Tell me all the readings, and I can tell you the problem and now to fix it.
Old Aug 5, 2016 | 08:49 AM
ShaWING66's Avatar
ShaWING66
Oh wow, didn't get notified of all these responses. I'll definitely check these all out.
Idling with AC on was above 14V on HUD. Haven't dived in yet. I also noticed that when I go to WOT that the voltage drops as my RPMs increase. Normal?
And to the other guy, yes. A lot of people have trouble with the NKG tr55 or whatever. The gap might be wrong and they are meant more for blown cars.
Old Aug 8, 2016 | 11:03 AM
Dano523's Avatar
Dano523
No, the problem is they don't have the needed resistance to act as RF noise suppressors (why the stock plugs and wires have the higher resistances in the first place).
Hence with the plugs, you get RF noise back through the coils to the ECM, and since the ECM is controlling the output voltage of the alternator as well, The RF feed back noise in the ECM ends up with the ECM clipping the normal 14.6 volts of the alternator, down to much lower voltage isntead.
Old Aug 8, 2016 | 04:24 PM
ShaWING66's Avatar
ShaWING66
If it's the link (fusible link? From the starter to the solenoid?), is that something easy to fix? Does it take a specialist?
Old Aug 9, 2016 | 08:30 PM
Dano523's Avatar
Dano523
And your voltage reading from the areas I asked are?????
Old Aug 10, 2016 | 08:02 PM
SpinMonster's Avatar
SpinMonster
I posted quite a few times on this issue but it has dropped from recent posts so it isn't popping up in a search. Changing your spark plugs will fix the issue with the charging system. It has to do with the voltage/current read by the PCM which does a sum check. I've seen the fix work so many times yet people resist the advice. I guess it is common to after market plugs.
EDIT: Do a search for 'C6 charging system spark plugs' on google
Old Aug 10, 2016 | 08:22 PM
timd38's Avatar
timd38
I was talking to the Autolite guys at the drags about that. They say it is problem, of course, they said it wasn't a problem with their plugs because their resistance is consistent. They claim the reason it happens with competitors products is because the system checks the resistance and sets the light off if there is much variability. To quote him "the plugs act a safety check".
Not saying what he said is right or wrong, just reporting what he told me.
Old Aug 10, 2016 | 10:23 PM
SpinMonster
Hi, good to see you on here.
I had the issue and plugs always fixed it but as my car was a 19lb boost, I had to use colder heat range plugs so I dealt with it happening every few thousand miles. The first time I swapped them and it jumped up to 14.4v, I thought it was a fluke so I put my TR6's back in and donw to the low 12's it went. I'm a believer.
Old Aug 11, 2016 | 07:21 PM
Dano523's Avatar
Dano523
Yep, and the Ac Delco 41-602 is the colder plug used in the ZR1 (colder than the plug used in the LS2 and LS3), and has the needed resistance to prevent the problem.
Old Aug 11, 2016 | 09:02 PM
SpinMonster
Good to know. Thanks for posting.
Are they 1 heat range colder?
To Another charging system warning
