A/C issues
Old Aug 11, 2016 | 04:04 PM
Madstriker75's Avatar
Madstriker75
Default A/C issues
My car has the climate control settings and now when it's warm enough to kick the A/C on only cold air comes out of the passenger vents and the driver vents blow ambient air. Anyone have any ideas what's going on? I had my performance shop refresh the refrigerant back in March as it wasn't blowing cold air at all at that point. Just seems like this started happening recently (last couple weeks). Thanks!
Old Aug 11, 2016 | 04:12 PM
Madstriker75
More info....dual climate control and when both sides are set on the same temp (say 70) it blows cold air on the passenger side with ambient air on the driver side.
Old Aug 11, 2016 | 04:14 PM
badass68's Avatar
badass68
Low freon.
Old Aug 11, 2016 | 04:23 PM
RicK T's Avatar
RicK T
What year car?
That is a common symptom when the mode doors are malfunctioning, more common the older the car is.
Old Aug 11, 2016 | 04:42 PM
Madstriker75
2007 Z06 w/ about 52,000 miles.
Old Aug 11, 2016 | 05:00 PM
badass68's Avatar
badass68
It's low freon! Happened to me. Do a search and you'll find proof.
Old Aug 11, 2016 | 05:23 PM
Madstriker75
I just had the refrigerant recharged back in March and I've only put maybe 800 miles on the car. If it's low again I must have a leak somewhere. The last time I was low I couldn't get any cold air out of the vents though. This time it's cold out of passenger vents but not driver vents. Almost seems like a control issue with the system and not recognizing it needs to use cold air on the driver side.
Old Aug 11, 2016 | 06:37 PM
badass68's Avatar
badass68
Believe me, I thought the same thing. I even pulled my drivers side actuator off and tested it. After reading many posts, I finally evacuated the system and refilled it by freon weight. Works great and cools both sides.
Old Aug 11, 2016 | 08:20 PM
jft69z's Avatar
jft69z
What kind of temperature are you getting out of the passenger duct?
Old Aug 12, 2016 | 11:56 AM
Madstriker75
I'll have the shop check Freon levels and make sure it's full first.
jft69z.....not sure exactly the temp coming out, but on a hot day (90+) and the climate control set at around 72 on both side, you can feel cold air coming out like a typical A/C unit but the air coming out the drivers side doesn't feel cool at all.
Old Aug 12, 2016 | 12:06 PM
Cherokee Nation's Avatar
Cherokee Nation
Why not just turn off the passenger side? In the 100 degrees temps here I'm getting Very cold air from the top two vents to cool the cab.
Old Aug 12, 2016 | 01:56 PM
jft69z's Avatar
jft69z
The reason I'm asking is to see if the system is capable of adequate cooling. If you're set to max cool and getting 42 degrees out of the pass. side and 75 out of the driver side (just an example), then we at least know the system is capable of good temps. Sounds a bit more like an air diversion issue (without actually being there).
Get a small thermometer & get some readings on max cool, recirc. turned on.
Old Jun 11, 2023 | 04:56 PM
drdrwood's Avatar
drdrwood
I am going to try that. Thanks
To A/C issues
