C6 fuel pump
Old Aug 16, 2016 | 08:53 PM
Crash58's Avatar
Crash58
6th Gear
Default C6 fuel pump
Is this an issue on C6 corvettes with the unit leaking. Fuel was pooling on top of driver side tank. My son is a mechanic so the problem was taken care of,but will this give me problems? By the way you don't have to drop out the rear end to fix it.
Old Aug 16, 2016 | 09:05 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
A. we know you don't have to drop the rear and tranny to fix it
B. not an issue I've heard of
C. what was actually leaking?
Old Aug 16, 2016 | 09:25 PM
Crash58's Avatar
Crash58
6th Gear
Had a strong gas odor found line out was leaking on driver side unit. Miles on the 2009 was only 26,000 miles. Just strange. I had heard that they had a problem with the fuel system.
Old Aug 16, 2016 | 09:30 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Weird, I haven't heard of that being a common issue, but maybe I just haven't heard of it
Old Aug 16, 2016 | 09:34 PM
Crash58's Avatar
Crash58
6th Gear
Yes there was a problem with that it was a defect in the plastic where it would crack and spray out there is utube video
Old Aug 16, 2016 | 11:55 PM
Mike's LS3's Avatar
Mike's LS3
I received a TSB for replacing the fuel pump for my 2008. Some pumps were experiencing cracking on top near the fittings. GM will replace the fuel pump on their dime, if you experience this fuel issue.
Old Aug 17, 2016 | 03:24 AM
torquetube's Avatar
torquetube
See the first sticky at the top of C6 General.
Old Aug 17, 2016 | 09:44 AM
Unreal's Avatar
Unreal
Common issue and a TSB finally out.
Old Aug 17, 2016 | 06:31 PM
Cherokee Nation's Avatar
Cherokee Nation
I got the letter for my 08 last month.GM is sending them out in phases due to parts availability. I've had the problem for a long time, problem is the fuel pumps are back ordered..They must be on a slow boat from China.
To C6 fuel pump
