dielectric grease
I bought some AC Delco iridium plugs and Delco wires. When I put the dielectric grease in the boots, should I avoid getting it on the metal connector surfaces? Wouldn't dielectric (non-conductive) grease inhibit the current flow? Also, what about anti-seize on the threads? Torque specs? I will probably not be alive when these plugs hit 100k miles.
Thanks in advance!
di·e·lec·tric
ˌdīəˈlektrik/Submit
PHYSICS
adjective
1.
having the property of transmitting electric force without conduction; insulating.
noun
2.
a medium or substance that transmits electric force without conduction; an insulator.
Thanks in advance!
Your fine with it on the contacts, but your using in on the boots inner surfaces so when you install the boots on the plugs, it allows the trapped air to escape out (so the boot does not have built up air pressure to expand when it get hot and pops the boots off the plugs). so a little on a Q tip goes a long way to grease the inside of the boots (both sides, hence boot for the plug, and for the coils)
On the plugs, if you are going to pull then say every 30K to clean and check the gaps, then anti-seize grease on the plug threads. If you are going to just change the plugs out every 100K, then they come pre-treated already, and don't have to apply anything to them when they are installed.
As for removing the spark plugs, make sure that the heads are bone cold first (hot heats will end up with stripping the threads out of the channel.
As for the spark plugs, torqued to 11ftlbs only.
di·e·lec·tric
ˌdīəˈlektrik/Submit
PHYSICS
adjective
1.
noun
2.
Orion2011 posted a video saying not to get it on the metal contacts - which makes more sense to me.
Distilled water is a dielectric but I wouldn't try putting my hand in a bowl of distilled water with a hair drier laying in it.
I understand what the grease does and have seen many cars all different ways without issue but unless you had a loose end inside your boot I'm not understanding why the grease would matter. It can only prevent the passage of electricity if there is no contact of the conductive materials.
He said there is no concern at all about getting it on the metal portion inside the boot. Additionally, the instructions on the box do not say to avoid metal contact. I think the key is where the instructions say "thin layer." My opinion is that the main benefit of the product comes from having it on the rubber and ceramic surfaces.
On the battery terminal instructions, it it says: "coat both parts of terminal contact...and reassemble maintaining metal to metal contact."
I'm not sure how you could reassemble and avoid metal to metal contact.
We need them and God bless em, but something tells me an attorney had a hand in writing these instructions.
Highest regards, Monte
Hence when GM installs the plug wires during assembly, the boots have a light silicone spray layer on them, and they slip into place without problems. The glitch, the silicone dries out pretty quickly in the boots, and when you go to remove the boots at a later date, you dam near end up tearing the boot off the plug instead.
So with the dielectric grease (silicone grease), it does not dry out like the silicone spray, and down the road when you decide to change the plugs, your not killing the spark plug wires boots trying to get them off the spark plugs isntead.
So either silicone spray or dielectric grease (silicone grease) will work fine, since your just using such to release the air that is being trapped in the boot as it being forced on to the plug (so the trapped air does not expand with heat, and pop the boot back off the plug/coil socket isntead).
And to add, if your tearing the motor down event by event, then silicone spray works a lot better isntead (less mess to clean up as your putting the motor back together each time, plus your going to add a new fresh shot of spray to the boots when your putting then on so no fear of the spray silicone drying up before you pull the boots again.
On the battery terminals. Install the terminals than put the silicone on top and around it liberally. Not before, do not get in between the post and the round terminal the two will make contact.
In other words dielectric grease is used around the items such as plugs battery posts and connectors not in between posts where clean contact is necessary for smooth flow or current. Same with large bulk head connectors, it seals and protects around the terminals to keep from dirt and moisture getting in and corroding the contacts.
We have not yet invented a better mouse trap.
P.S. I buy wires with Silicon boots.
I'd like to play some more but right now I need to pull an axle shaft, in the heat, in my garage.
There is a tradition with dielectric grease that goes way back, it was used to coat electrical connections to prevent against moisture ingress. Unfortunately, dielectric grease is an insulator, not a conductor. So, even though this was misunderstood then, in order to work, old 12V analog connectors still needed to push/scrape the dielectric grease off the male female connectors and make metal to metal contact in order to complete a circuit. With today's much more sensitive circuits, applying an insulator to the connection ends of circuits is far more risky.
Dielectric grease, if used at all, should be used very sparingly on the non-metalic contact points in male female connections and not on the electrical contacts themselves. And, it is really intended to create a barrier from contact corrosion of the non-metalic parts caused by heat and time, and to facilitate non-destructive removal. Modern day automotive electrical connectors are better assembled dry.
Anti-seize on spark plug threads is another older tradition that came about when aluminum heads were becoming popular. Made sense then BC of the corrosive reactions of steel when in contact with aluminum. Since aluminum heads have become more the norm than the exception, spark plug manufacturers now plate the threaded surface of the plug with material that has no corrosive reaction to aluminum, so it is a tradition no longer necessary.
