removed tanks, now no fuel pressure
I removed my fuel tanks to gain access to roll bar fasteners. Put the tanks back in. I'm getting plenty of fuel to the fuel rails but there is practically no pressure. Plenty of flow, no pressure. Therefore the engine hits but wont stay running.
What can prevent the pump from developing pressure. I don't hear the pump but never have heard it. I get good fuel flow from the end of the fuel rail when I remove the schrader valve.
The tanks are full. Car ran fine before removal.
You may actually be seeing residual fuel at the rail. If there is no pressure I would want to think that the pump isn't getting power. You can definitely hear the pump if you just turn on the ignition without starting.
The pump is definitely pumping. Fuel comes out the end of fuel rail at a full stream. But I can put my finger over the hose and completely stop the flow with no effort.
Race Car Tech
Here are some pics of description of fuel system
Hope they help some:
Thanks for that information. It was helpful and gives me a few more things to consider that I would not have otherwise known. I believe the regulator could be the issue. The bad news is it all still has to come out. Bummer
The cross over lines probably didn't seat correctly, so it is just pumping the fuel back into the tank.
I considered that as a possibility. All the fittings were in they're locks to hold them in place. So I felt confident about it. But I'll know for sure tonight.
None of this would bother me nearly as much as it does, if I didn't have a bad back (a few ruptured discs) and I'm doing this without a lift.
Well, I got it running again.
Apparently the cross over tube was the problem. Although the locks on both ends of the tube were fully engaged, something was still misaligned.
Pulled the drivers tank and tube. I put a full twist in the hoses inside the tube help it stay locked into the small catches. Everything went back together the same as before, at least from a "feel" standpoint. Hooked up the battery, hit the ignition. We have lift off. Thank Goodness. Thanks for all the comments
Next step is to see if you run out of gas at 1/2 tank because the transfer pump isn't working. Be prepared for the 1st time.
