Pls any idea help me
Hi
My corvette c6 2006
It was heavy rain and water go inside
Even inside that fuse box under on passnger side
Then i try 2 start the engin bt no more battry
I fix another and i start the car it was good
No message and its normal only no sound
Speaker and seat nt moving
The proplem after 4 days i want to start the car
Bt no even crank
Abs and brake light on
Vhicle service soon
Anti brake system service
No Gm in our city and if i want 2 ride its cost more than 700$
I buy dignostic scan
Autel maxidiag md802 all system
I do scan i get this codes
U1096
U1000
U1301
U1327
U1064
U2108
i read the code bt idnt have idea 2 solve this proplem
I check the fuse box in hood all its good
And i check fuse box in passnger side
I found this fuse nt working bt fuse good its like no voltge or low
HTD Seat
Ecm
Sdm/psir
Havc
Cruse
tonneau
Even the ingition on
And no sound on speaker also peep sound when u lock or open the door
So pLs help me and how i will solve this proplem
My corvette c6 2006
Bt no even crank
Vhicle service soon
U1096
U1000
U1301
U1327
U1064
U2108
HTD Seat
Ecm
Sdm/psir
Havc
Cruse
tonneau
All of the "U" OBD codes are "communication" related fault codes.
When water got in that fuse panel under the passenger floor it also got to the BCM. The BCM is the main computer that coordinates the systems in the car. It is the box below the fuse panel with the big blue connectors on it.
I'm only guessing but by putting power to the car with that BCM wet, you've likely shorted it out. If your car has Bose stereo, the Bose amplifier is right there also so it is likely shorted as well.
You can start replacing the electronics but I can't guaranty you will fix everything. In my opinion it would be well worth the cost of getting the car to a GM facility for proper diagnosis and repairs.
Good luck.
Just curious, where are you located?
Good luck.
If the BCM is replaced you WILL have to have it reprogrammed… I would disconnect the battery, take EVERYTHING in the pass side foot well OUT, use an air gun and blow ALL the water out of the Well and the boxes & the connectors.. try again ( but I fear the damage is done ) IF IT WORKS get some dielectric grease and disconnect the battery, and coat all the connectors with that, so corrosion doesn't sneak up on you...
Id like to suggest staying away from ebay as well for something as important as body/engine control modules.
You might spend another $100.00 buying new but you will have piece of mind in knowing the part has not been wet before just like yours.
Guys....will a tech2 reprogram the BCM? If so, buying a tech2 clone from a good supplier on alibaba express might help him as he moves through this and for few hundred dollars have a good tool to keep.
It's more of an issue that a used BCM is basically a paper weight.
Thanx all soooo much all rili help me r
I will tell what i do
Last thu i open and i take out fuse box and bcm and
i clean it and i change 2rely ( back of fuse box)x
I change it with 2rely from hood
Then i make relearn for bcm i read befor here
The car started
Then i switch off after 20 min
Then i try again 2 start bt no crank bt no message
Already am tired
Next day i start the car its good and no more message
I notic head light nt working bcoz that rely its damage
I bring new and i fix now all is good
Stil only no sound and both seat nt moving forwards and backwards
The sound am sure its from amplifier boose
Bt seat i dnt know
I will open the amplifier and check
I will post any update
And i will make again scan for any code
Thanx again and again
The car started
Already am tired
Bt seat i dnt know
