Pulling C6 fault codes
Old Sep 3, 2016 | 03:56 PM
autocolor's Avatar
autocolor
Default Pulling C6 fault codes
Is it possible to pull fault codes via the DIC on a C6 like the C5? If so what is the process please
Mike
Old Sep 3, 2016 | 04:00 PM
jft69z's Avatar
jft69z
Originally Posted by autocolor
Is it possible to pull fault codes via the DIC on a C6 like the C5? Mike
No.
Old Sep 3, 2016 | 04:16 PM
autocolor's Avatar
autocolor
Thanks that's what I thought its just a few folk over here were suggesting it could be done, the car has been on the tec2 but I was just curious
Old Sep 3, 2016 | 04:24 PM
jft69z's Avatar
jft69z
A Scan tool or cheaper type of code reader is all that will work to pull codes now.
My old Cadillac Eldorado ETC used to be able to pull codes thru the DIC. It was a handy way to get info quickly, but was a bit of a pain to navigate thru the info.
Old Sep 3, 2016 | 05:04 PM
teesee150's Avatar
teesee150
You can pick up a cheap scanner from Amazon for like $15~20 shipped. Great investment as it will also clear the codes!
To Pulling C6 fault codes
