Line lock issues dash lights
Old Sep 6, 2016 | 07:22 AM
corvettepower's Avatar
corvettepower
Default Line lock issues dash lights
Any one had any issues with there abs active handling lights comin on when using line lock.
Old Sep 8, 2016 | 11:48 PM
irok's Avatar
irok
your turning off the traction control when you use it?right
Old Sep 14, 2016 | 03:38 AM
corvettepower
Yes I am
Old Sep 15, 2016 | 02:46 AM
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
Yes mine does it every time I use it. Sometimes after a burnout at the track I will shut the car off and restart it to clear the ABS light. Don't know why it's doing it but it seems to not be harming anything.
Old Sep 15, 2016 | 02:54 AM
corvettepower
yep I have to do exact same thing. Do u have tire pressure light on? I have a tire light on because I don't have pressure sensors in my wheels I wonder could that have anything to do with line lock triggering abs light.
Old Sep 15, 2016 | 07:50 AM
irok's Avatar
irok
that's your problem I would think.no issues with mine.has the active handling put 1 front brake on yet at speed and tried to kill you?
Old Sep 15, 2016 | 10:53 AM
corvettepower
yes going thru a curve if u not ready for it it will surely put u in the ditch
Old Sep 15, 2016 | 08:21 PM
Heavy Hauler's Avatar
Heavy Hauler
that is not the problem as it does it with either my factory wheels with sensors & my Bogarts without sensors.
Old Sep 15, 2016 | 09:41 PM
corvettepower
so this issue is normal no fix
Old Sep 17, 2016 | 12:40 PM
irok's Avatar
irok
your car has an issue if running correct pressure range with factory wheel and proper tps's
Old Sep 17, 2016 | 12:42 PM
irok's Avatar
irok
simple cure.fix the sensors
Old Aug 8, 2017 | 01:00 AM
corvettepower
Default Abs light line lock issue
Have u found a cure for the abs and line lock issue
Old Aug 8, 2017 | 05:39 AM
Heavy Hauler
yea, I sold it for a CTSV and have not looked back.
Old Aug 8, 2017 | 01:35 PM
Unreal's Avatar
Unreal
Had a linelock for 6+ years now. Never had this issue or a single issue with it.
Old Aug 8, 2017 | 03:23 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Me neither, on two different cars. No sensors in any of the wheels and once or twice I've even forgotten to turn off TC but still didn't have any issues.
To Line lock issues dash lights
