Ls7 Head torque secuence
Old Sep 11, 2016 | 11:57 PM
zblackz06's Avatar
zblackz06
Default Ls7 Head torque secuence
Hey guys,
Is there a specific torque secuence for the Ls7 head?, I read one write up and it sounds like you torque the head then go 90°,loosen then torque back to spec.
Does this sound some what correct?
Old Sep 12, 2016 | 07:46 AM
Brandon619's Avatar
Brandon619
Here is a DIY link.
https://www.corvetteforum.com/forums...-headswap.html
Old Sep 12, 2016 | 12:23 PM
zblackz06's Avatar
zblackz06
Thanks, I read through the procedure and in there he doesn't just torque the heads once and forget it, he torques them then loosens them and retorgue and goes like 90° more.
My question is do you need to go through the process listed or could you just torque the heads to the desired ft lbs. and move on?
I think the reason he did it the lengthy way was to seat the head/gasket.
Old Sep 12, 2016 | 03:21 PM
outhouse's Avatar
outhouse
No they are TTY bolts. Do it right or do not do it
Old Sep 12, 2016 | 04:17 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There isn't a final desired ft lbs--that's the whole point
You have to go through the whole procedure for TTY bolts.
Old Sep 14, 2016 | 01:01 AM
KENS80V's Avatar
KENS80V
That process is only for stock GM bolts. Are you using ARP fasteners?
To Ls7 Head torque secuence
