2011 GS front splitter height
Old Sep 12, 2016 | 09:28 AM
Detroit1's Avatar
Detroit1
Default 2011 GS front splitter height
Hello,
I just picked up a 2011 GS Coupe and driving back home I noticed that it is really low and I have to come to complete stop on speed bumps. It does scrape the lower air dam.
I measured from the ground to the lip of the Splitter and it is 4". Seller said he did not turn lowering bolts. If any one has this same model I would appreciate if they could check their height and respond to my post.
Other than this one issue, I really like the car and the previous owner really took pride in keeping it in excellent condition.
Thanks,
Jim
Old Sep 12, 2016 | 10:58 AM
61X's Avatar
61X
I have an 11 GS vert. 4 1/2" at the center on mine.
Old Sep 12, 2016 | 03:07 PM
HK770's Avatar
HK770
Second owner:
11 G.S. coupe 4" at center......luck
If I have to cross speed humps, turn around and go home.
Old Sep 12, 2016 | 06:31 PM
Detroit1's Avatar
Detroit1
Originally Posted by HK770
Second owner:
Thanks for input. Not sure if magnetic suspension makes the car any lower or just firms it up.
Tempted to take a jack hammer and remove the 5 speed bumps in our sub.
Jim
Old Sep 12, 2016 | 06:37 PM
Hallett's Avatar
Hallett
Try taking the speed bumps at a angle that might do the trick works for me. 👍
Old Sep 12, 2016 | 07:10 PM
HK770's Avatar
HK770
Default magnetic ride
Jim
Also have magnetic ride. lucky not to have to deal with in Humps in my area.
Hk
Old Sep 12, 2016 | 09:03 PM
GaVette61's Avatar
GaVette61
You are most likely hitting the air dam under the nose rather than the splitter. While I haven't measured mine it looks like it is about 3 inches or less off the ground. Mine hits almost everything and is beat up but it is tough and I can replace it later if I want. Angle entry and crossing is your friend. At first I freaked every time I heard that scraping noise, now I am used to it. The splitter is not normally damaged unless there is a major dip or bump or if you hit a parking curb.
Old Sep 12, 2016 | 09:33 PM
NMJoe's Avatar
NMJoe
4.25" to the bottom of my stock 2012 GS splitter (F55 car).
Old Sep 13, 2016 | 09:14 AM
dr_gallup's Avatar
dr_gallup
There are two "official" ways to measure ride height. The Kent-Moore J042854 trim height gauge or just use a yard stick to measure the tops of the fender arches. The stock GS heights are 27.3+/-.4" front and 28.2+/-.4" rear. My GS was lowered over 2" in the front and couldn't cross a crack in the road. As a daily driver, it's so much better at stock height.
To 2011 GS front splitter height
