LS2 lifter chatter
Old Sep 12, 2016 | 11:48 AM
GrizzlyCorvette's Avatar
GrizzlyCorvette
Default LS2 lifter chatter
I'm having a bit of chatter from under the hood while under load. I assume its the lifters and/or springs. Im in the process of aquireing the new parts to rebuild the heads and new LS7 lifters anyways, and while im at it a cam. Does anyone have any insight on what it is that I'm hearing?
Old Sep 12, 2016 | 03:22 PM
outhouse's Avatar
outhouse
Normal
They almost all do it.
Old Sep 12, 2016 | 04:09 PM
GrizzlyCorvette
OK, the reason I ask is because, yes A LOT of LS owners report it but almost everyone says something different. I wasn't sure if it is in fact something to be concerned about. I appreciate the response.
Old Sep 12, 2016 | 04:38 PM
extrapilot's Avatar
extrapilot
Could be a produce of the typical overhead V8 valve noise, but if you could post a audio track, that would be helpful to verify your noises.
Old Sep 13, 2016 | 02:56 PM
1FastAzzC6's Avatar
1FastAzzC6
Hi, after all my engine extras and (at the time) was enjoying my 500 plus ponies....i must admit, i ran her one helluva lot harder than i probably should have and after half a dozen runs on my favorite curvy high speed canyon rd., I noticed that noise your taking about a both at idle and right as i turned it off. Believe it or not, i added maybe a quart, of Lucas synthetic oil stabilizer (full synthetic) and wah lah, noise gone!! I think everybody's right about once your pushing over 500 you deff need a thicker and tougher oil. RD/LA
To LS2 lifter chatter
