Tmps
Old Sep 17, 2016 | 10:04 AM
ram01's Avatar
ram01
Default Tmps
Just received received alert service tire pressure monitor. When I checked left front had XX any ideas. Thanks
Old Sep 17, 2016 | 10:36 AM
EVRose's Avatar
EVRose
What year is your car and how old are the sensors?
Old Sep 17, 2016 | 10:47 AM
ram01's Avatar
ram01
2005 I believe original.
Old Sep 17, 2016 | 11:05 AM
jrose7004's Avatar
jrose7004
The battery died in the sensor and you need to replace it.
Old Sep 17, 2016 | 11:18 AM
ram01's Avatar
ram01
Is it ok to drive till I get app.
Old Sep 17, 2016 | 06:13 PM
GOLD72's Avatar
GOLD72
You should be fine until replacement. I have a RR sensor that every couple of weeks will go to xx at the same spot on the freeway. I think RF interference is overwhelming a weak battery in that TPMS. After arriving at work and parking for the day, it is back to normal later in the day. Been doing this for a couple of years and the car is now just 5-1/2 years old. Will have both rear sensors replaced when I get the first set of replacement tires for the rear.
Old Sep 17, 2016 | 06:15 PM
GOLD72's Avatar
GOLD72
Definitely time to replace them if original sensors.
Old Sep 18, 2016 | 07:40 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
GM and Schraeder (sp?) are both good.
Some of the aftermarket sensors, not so good.
To Tmps
