Error Codes P1516, P1682, P2176, U0101
2005 C6 was sluggish at the low end. Heads up display not projecting, engine light on and in a steady on state. Lost communication with the TCM.
P1516 CHEVROLET - Throttle Actuator Control Module Throttle Actuator Position Performance
P 1682 Faulty Engine Control Module (ECM)
P2176 Faulty Throttle Actuator Control (TAC) module
U0101 Lost Communication with TCM
Reading this forum I found info leading to bulletin #08-07-30021E: Loss of High Speed GMLAN Communications... and deduced the following:
Fix was to locate 16 way electrical connecter on right side of automatic transmission. Disconnect, clean, and reattach.
Upon restarting- DTC's cleared from the car. Re-ran diagnostic code reader, no new codes. Test drove, and car is now back to perfect working order.
Jack Shelton
Jack Shelton
There is a much longer thread on this subject under my name, suggest you read those for more help... I went into a lot more detail about the what I learned was causing the problem.
search my name in the search forums
Hope this helps,
Dave...
