has anyone split the case on a BCM
Sep 21, 2016 | 12:26 PM
I want to see whats going on inside a BCM on my C6
I wondered if anyone has ever managed to split one open, I have prised the clips open and removed all of the fuses and relays but despite some pressure on several screw drivers I cannot get it to split, I can just see the electronics inside but I want to thoroughly clean all the contacts and components
Any ideas would be awesome, thank you
Sep 21, 2016 | 07:20 PM
Quote:
Originally Posted by
Martyn
I have to ask .... why would you want to open a a perfectly good sealed unit if it is working fine ?
There are BCM'S that operate for years and years and have never been cleaned
Sep 21, 2016 | 08:47 PM
nothing to clean inside, I believe the term is Solid state
Sep 22, 2016 | 09:02 AM
Got uid0
did you take the 3 silver bolts running down the center out?
Thanks, that is what I thought I was not certain.
I think its past its best so will see if i can find a way to remove the 3 silver bolts
I appreciate you responding
Thank you
Sep 22, 2016 | 09:04 AM
Dcasole
I didnt say it was a perfectly working unit, the reason I want to open it up is that it is NOT working
I am an electronics specialist and want to trace the damage to it and 2 others I have
I have new replacements on order and use a Tech II to program them and I usually mess with C5s but I have several C6s right now that need attention
Sep 22, 2016 | 09:06 AM
CMY SIX
Corrosion, which will cause a short, done it so many times before with sucess as long as the car has not been powered up
Despite having new BCMs ordered that I can program I still want to have a go at repairing these, its my personal challenge
Martyn
Thank you
Share pictures if you don't mind. Just curious what it looks like. My bet is a board with stuff on it and plugs.
Sep 22, 2016 | 09:07 AM
timd38
its like a compact version of the C5 BCM board, its very similar to a Jeep BCM with fuse block and relays attached
Sep 22, 2016 | 10:34 PM
St. Jude Donor '17
timd38
pictures
https://www.corvetteforum.com/forums...operative.html
Sep 22, 2016 | 10:37 PM
St. Jude Donor '17
Martyn
For some reason i thought you were working on the fuse box under the hood.
Sep 23, 2016 | 09:28 AM
Got uid0
Thank you for responding, no I am working on the BCM modules in the passenger footwell and then after that the Bose power amp modules
I will have time this weekend to hopefully mess with one of them, I have replacements on the way just my Tech II tool the Candi interface has quit on me so waiting on a replacement.
My biggest enemy is lack of time
Sep 23, 2016 | 10:14 AM
Martyn
Now that changes things a bit
Now I know where to go if.........
Dave
Sep 24, 2016 | 10:46 AM
Dcasole
Dave
I have managed to get 3 out of many C5 BCM modules to work just fine, this is the first time messing with C6s
I am not guaranteeing
I can get them operational but sure am going to try
Sep 24, 2016 | 10:52 AM
Martyn
That is awesome !!
