BTR LS7 Titanium Beehive Retainer
Sep 21, 2016 | 05:51 PM
Brian Tooley Racing is Officially the first to market with a Titanium beehive retainer for LS7 and LS9 applications.
Using this retainer with a set of PSI 1515 or Comp Conical Springs would be a great upgrade, for anyone looking to upgrade cams.
The SR010 Titanium retainer is around 5 grams lighter than a stock LS7.
Visit the website and see what we can do for your LS7.
http://www.briantooleyracing.com/sr0...set-of-16.html
Sep 22, 2016 | 10:34 PM
Can this retainer be used with a stock
ls7 spring?
Sep 23, 2016 | 09:36 AM
Quote:
Originally Posted by
548chevelle
ls7 spring?
Yes they are a direct drop in for stock LS7 Springs as well.
Sep 23, 2016 | 10:41 AM
Would also work on PSI 1511's as well, correct?
Sep 23, 2016 | 11:00 AM
geezel
The SR010 Retainer will not work with the 1511 do to the shorter install height of the PSI 1511 Spring
PSI 1511 1.800" install height
PSI 1515 1.950" install height
If you are running the PSI 1511, you can use the SR007 Titanium retainer.
http://www.briantooleyracing.com/tit...e-springs.html
