Cam advice
Old Oct 21, 2016 | 05:14 PM
Dustyprice's Avatar
Dustyprice
Default Cam advice
Hello everyone
I'm looking at the g5x3 cam for my ls2 and I was wondering what's everyone's opinion on what j should do and not do while there
I obviously know springs, retainers
maybe
pushrods?
Oil pump?
Timing chain?
Let me know what route i should go.
Thanks in advance
Old Oct 21, 2016 | 08:13 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Push rods yes
Oil pump depending on mileage
Timing chain
Timing gear
Retainer plate for cam bolts
If it'll ever possibly be supercharged, pin crank/balancer while you're at it
Old Oct 21, 2016 | 08:15 PM
Dustyprice's Avatar
Dustyprice
It won't be supercharger
It has 46k on it
Old Oct 21, 2016 | 09:23 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I wouldn't change the oil pump at that mileage personally
Old Oct 21, 2016 | 09:31 PM
Dustyprice's Avatar
Dustyprice
What about timing chain?
Old Oct 21, 2016 | 10:05 PM
Brandon619's Avatar
Brandon619
I did a cam job recently and I had 39,000 miles on the clock. I replaced my oil pump, timing chain and balancer pinned just for reference.
Old Oct 21, 2016 | 10:06 PM
CMY SIX's Avatar
CMY SIX
use a C5 racing chain, new gear{cheap insurance) I put in a NEW Melling M295 oil pump in for $100 bucks you can't go wrong, while your in there. my pressure went up 5 psi, don't worry about "high pressure or volume" pumps. M295 is just a better pump then stock! the crank gear is a PITA to remove don't worry about it, just the cam gear and a ARP bolt kit for the cam and HB, I also filled the new pump with oil as best as possible before install.
Old Oct 23, 2016 | 08:50 AM
turboffr's Avatar
turboffr
St. Jude Donor '10
C5R Timing chain
BTR .660 spring kit (titanium retainers)
Pushrods (BTR, Comp, etc.)
ARP cam bolts
ARP balancer bolt
Pin crank (you could also upgrade balancer now)
Timing cover crank seal
Rocker trunion upgrade (very happy with the Straub bushing kit)
Old Oct 23, 2016 | 11:42 AM
Dustyprice's Avatar
Dustyprice
Do y'all have any links for all the parts you used so I can start pricing them out
Old Oct 23, 2016 | 08:48 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Start here....
http://www.briantooleyracing.com/
Old Oct 25, 2016 | 04:05 PM
Steve Haefner's Avatar
Steve Haefner
2018 C6 of Year Finalist
Originally Posted by schpenxel
Push rods yes
Timing chain
Timing gear
Cant go wrong with BTR, they have a "cam" kit that makes it easy http://www.briantooleyracing.com/btr...ation-kit.html
Take a look at their Cams too, call and talk to Chris (good peeps)!
To Cam advice
