M6 trans cooler lines question
Old Nov 4, 2016 | 07:59 PM
UmX's Avatar
UmX
Default M6 trans cooler lines question
Can they 1) be removed ? and plugged at the trans ? or can they be removed and replaced with braided steel hosing.. the ones by the header are too closet to the ground and rub against the header ..
Old Nov 4, 2016 | 08:35 PM
C6smackdown's Avatar
C6smackdown
I replaced mine with braided
Old Nov 4, 2016 | 08:38 PM
UmX's Avatar
UmX
happen to have a parts list>?
Old Nov 5, 2016 | 12:06 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Yes, several options to either swap them with stainless or just eliminate them by looping output to input.
I'll dig up parts to do it tomorrow
Old Nov 5, 2016 | 02:32 PM
Unreal's Avatar
Unreal
I just put a rubber tranny line between the two in the rear with hose clamps. It is not a high pressure system.
Old Nov 5, 2016 | 02:53 PM
UmX's Avatar
UmX
Is that go for all c6s not a high pressure system? And down sides just making it loop with no cooler?
Old Nov 8, 2016 | 07:19 AM
Unreal's Avatar
Unreal
Well, you don't have a cooler anymore is probably the biggest downside. If you road race or do something that requires a cooler that is bad. If you just drive around town, do some 1/4 mile/.5 mile stuff its fine.
Old Nov 9, 2016 | 12:15 AM
BlindSpot's Avatar
BlindSpot
This is pretty coincidental. I am in the middle of my AA install and don't like the run of the lines either. I don't do any road racing, will be lucky if I ever end up at a dragstrip. I'm tempted to cap mine off too. I'd like to eliminate the clutter around the SC.
Old Nov 9, 2016 | 06:46 AM
Unreal's Avatar
Unreal
Can't cap, have to loop.
Old Nov 9, 2016 | 08:00 AM
BlindSpot's Avatar
BlindSpot
I meant cap off the radiator ports, it's obvious the feed return lines need to be looped.
To M6 trans cooler lines question
