'05 DIC lights serviceable?
Old Nov 6, 2016 | 11:00 PM
mdvitacco's Avatar
mdvitacco
Default '05 DIC lights serviceable?
Trivial matter perhaps; most of the illumination on my DIC buttons are out. I removed the DIC, peeled back the rubber sheath to expose the circuit board, and attempted to pull out the small bulbs with a small needle nose. They did not want to come out and I did not want to force them. Does anyone know if these are serviceable?
Old Nov 6, 2016 | 11:32 PM
Dano523's Avatar
Dano523
Here are your bulbs, and the old ones will need to be de-soldered, and the new one solder back in.
Old Nov 7, 2016 | 06:40 AM
irok's Avatar
irok
new DIC pods are dirt cheap from GM
Old Nov 7, 2016 | 12:40 PM
4SUMERZ's Avatar
4SUMERZ
They are, but so are a handful of 7218 bulbs and a bit of solder.
Piece of cake to remove the pod, which has to be done by either decision.
I resoldered all the bulbs with new ones when the options bulb burned out.
Old Nov 8, 2016 | 03:00 PM
mdvitacco's Avatar
mdvitacco
Great thanks, I can solder, no problem!
Old Nov 11, 2016 | 11:25 AM
cclive's Avatar
cclive
If you know how to do small soldering, then replacing the bulbs is a great way to go, and having the info on the replacement bulbs in advance makes the project so much easier.
To '05 DIC lights serviceable?
