'06 C6 Corvette "Radiator leaking?"
Old Nov 7, 2016 | 03:08 PM
bruttix's Avatar
bruttix
Default '06 C6 Corvette "Radiator leaking?"
Hello, the past 2 days i actually noticed a 12 inch diameter circle roughly of coolant puddle under my car after leaving it alone after going out for some food. I move my car to a new parking spot for a dry surface and lifted it and this is what i seen : (youtube video) upon first inspection i thought it was my drain plugs but i think it coming from higher up. I wiped off the drain valve and drain cork yesterday for i at first thought that was the culprit but seems maybe not....?
Would LOVE any help. Also the upper and lower hoses are fine it seems, still squishy and the clamps are tight on the ends and no wet marks.
youtube link :
Old Nov 7, 2016 | 03:35 PM
RicK T's Avatar
RicK T
I can't tell from your video but if it is the original '06 radiator the problem is likely a split in the plastic tank. Very common issue. Here's one example:
https://www.corvetteforum.com/forums...-radiatir.html
Old Nov 7, 2016 | 03:38 PM
bruttix's Avatar
bruttix
Also this is the exact type of Radiator i have in my car, maybe the right side plastic tank cracked?
bruttix's Avatar
bruttix
Any idea what i should do mate? Do they sell the plastic tanks ?
Old Nov 7, 2016 | 03:43 PM
RicK T's Avatar
RicK T
AFAIK the tanks aren't separately serviceable, have to replace the radiator. If you look at that discussion I linked, you'll see that many owners upgrade to a DeWitt's all aluminum radiator, but they are a bit pricey.
Old Nov 7, 2016 | 08:34 PM
bruttix's Avatar
bruttix
Does ANYONE agree that if its a smile plastic leak that i should JBweld? OR IS THIS ABSOLUTELY a bad idea?
Old Nov 7, 2016 | 08:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I tried JB Welding mine--lasted about an hour
Time for a new radiator IMO
Old Nov 7, 2016 | 08:52 PM
bruttix's Avatar
bruttix
did u jb weld the plastic or the metal out of curiosity? Also i haven't just yet ruled it that my radiator is leaking. From watching my video would u say that is 100% a radiator leak? lower hose, and hoses look fine.
Old Nov 7, 2016 | 08:55 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
JB weld'd plastic part
They are known to crack so that's probably what it is. Haven't watched video
Old Nov 7, 2016 | 08:57 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
k watched video, looks like radiator to me.. they usually seem to crack on the front of the plastic end tanks
Old Nov 7, 2016 | 08:59 PM
bruttix's Avatar
bruttix
Alright, going to go take off my radiator (perfect timing because on daylight savings day it's super dark as soon as i get off work )
Any approximation on how long taking it off and installing a new one takes?
Old Nov 7, 2016 | 09:02 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Couple of hours.
Only tip I have is... the tabs on the condenser slide into plastic slots on the radiator. The easiest way to get the radiator out is to just break the slots off of the radiator since it's being replaced anyways. That will separate the condenser and radiator, which is half the battle in getting it out.
Otherwise it's pretty straight forward
The metal hoses (oil lines) come out pretty easy--there's a metal C shaped clip that you have to pull out with a pick, then the hoses will pull right out
Old Nov 7, 2016 | 09:04 PM
bruttix's Avatar
bruttix
Couple of hours.
Only tip I have is tabs on the condenser slide into slots on the radiator. The easiest way to get the radiator out is to just break the slots off of the radiator since it's being replaced anyways.
Alright, as for my car, 2006 c6 base coupe corvette i don't have the engine oil cooler radiator? i don't believe i do https://www.radiatorexpress.com/prod...aia_id=1432065 "this is the expected part i was going to order?"
Old Nov 7, 2016 | 09:06 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Oil lines are visible in the video
And are visible in the picture in that link
Probably transmission oil cooler
Old Nov 7, 2016 | 09:19 PM
bruttix's Avatar
bruttix
The dealership asked for my VIN and after providing them that they too said i don't have the EOC radiator. Not sure if prior owners added that upgrade but i don't think so.
The only thing i'm going off of is the left side of the radiator doesn't have a hose going in like this :
https://www.radiatorexpress.com/part...tepCompleted=5
sorry to keep bugging you mate, just don't want to buy the wrong part :\
dealership gave me part number : 10353980
: yes i believe that's the transmission oil cooler
Old Nov 7, 2016 | 09:31 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
That's probably it--if no metal hoses on drivers side then that that should be the right part number. Passenger side is for transmission oil cooler. Even some manual transmission cars got a tranny cooler
And $100 is a steal... I think I paid 3-4x that for one with both coolers
Old Nov 8, 2016 | 10:51 PM
mmorse's Avatar
mmorse
i think i have the same problem with my 08 Z51 coupe. anybody know what the right part number is for the radiator? seems to be more than one that fits my car.. I do have the oil cooler.
To '06 C6 Corvette "Radiator leaking?"
Old Nov 9, 2016 | 03:29 AM
bruttix's Avatar
bruttix
Call any local dealership and they will ask for your VIN (if you haven't ever been there before) and then they will give u the part number for the specific Radiator w/ EOC (what you need)
Old Nov 9, 2016 | 08:15 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Call dealership w/VIN
Or you can check the radiator yourself and see which coolers it has.
Old Nov 9, 2016 | 02:31 PM
bruttix's Avatar
bruttix
Replaced radiator, haven't pressure tested the old one but i assume it was leaking from the plastic passenger side tank.
