Shock Replacement
Old Nov 9, 2016 | 02:44 PM
Travlee's Avatar
Travlee
Default Shock Replacement
i am thinking of replacing the shocks on my 08Z, but not sure which ones to look into more. has anyone had experience with the Pfadt Johnny O'Connell signature series, bilstein hd, or bilstein sports
appreciate any insight and help. this is my daily for about another year or so... dont mind a little stiffer right
Old Nov 9, 2016 | 08:46 PM
CI GS's Avatar
CI GS
I did the JOC's. Can't say that they're much stiffer than the stock shocks that came on my GS, but the car seems to handle better and feels more "controllable" now if you're going around a bend at speed and hit a bump or dip. Basically, the car feels more nimble.
Lots of folks have done the Bilsteins and seem to be happy with those too.
Old Nov 10, 2016 | 08:57 AM
Travlee's Avatar
Travlee
i just wonder if the JOC are worth 75% more than the bilstein.
Old Nov 10, 2016 | 09:02 AM
CI GS's Avatar
CI GS
I doubt it. Bilsteins makes a very good shock. I actually wanted the Sports, but no one that I checked had a full set them in stock back then, and I had read somewhere that the bushings that came with them wasn't good or didn't fit good or something, so I ordered the JOCs.
Old Nov 10, 2016 | 02:11 PM
Al Gumby's Avatar
Al Gumby
Doug Rippie Motorsports has Bilstein sports revalved for C6's, especially Z06's. Order them with their upgraded poly bushings for a better fit. I have them on my base `08 coupe and they work very well.
Old Nov 11, 2016 | 08:56 AM
Brandon619's Avatar
Brandon619
I just recently installed a set of JOC shocks on my Z51. They are a definite improvement over the OEM shock.
Old Nov 11, 2016 | 09:34 AM
Travlee's Avatar
Travlee
hmmm, this actually peaked my interest. almost none of the others say they are for the Z06, mostly just z51 and gs. leaning towards these now
Old Nov 11, 2016 | 09:49 AM
Gary7's Avatar
Gary7
I put Bilstein HDs on my stock 05 C6 last month. Firmed up the ride a little, but suspension seems to accommodate bumps a lot better. Very pleased.
Old Nov 11, 2016 | 03:09 PM
WW7's Avatar
WW7
I put Bilstein sports on my base Z51 a few months ago, handles like a completely different car now .. I had stock shocks before the Bilsteins.. Bilstein makes a great shock..........WW
Old Nov 11, 2016 | 03:18 PM
Travlee's Avatar
Travlee
went ahead and ordered the DRM revalved hd bilsteins with the poly bushings. will post up my thoughts on them after i get them on
**edit, dang it... just realized that next weekend me and gf are doing turkey day with her mom and dad before they head out of town, then the next week is turkey day with my family (along with going to the cowboys game). may be a couple weeks before i get a chance to get them on
Old Nov 11, 2016 | 06:06 PM
Midnight08's Avatar
Midnight08
Don't intend to hijack the thread, so feel free to reply via personal message.
I'm wondering what is involved when swapping out the stock magnetic-ride shocks (tied into the system traction system) when going with these after market options that clearly aren't going to tie into this system?
I have a 2008 base coupe, though have installed the JOC sway bars front and back.
Old Nov 11, 2016 | 06:15 PM
Homer3D's Avatar
Homer3D
Replacing the F55 shocks is no different than replacing a regular shock, however, you will need to either (1) tune out the F55 or (2) install F55 shock simulators.
Old Nov 11, 2016 | 06:23 PM
Saltywheels's Avatar
Saltywheels
Just had WCC replace my antique OEM shocks with Bilstein HD & new simulators. Wow! What a difference. Feels so much more 'planted'
Old Nov 11, 2016 | 06:26 PM
Midnight08's Avatar
Midnight08
Interesting. I do have the F55 shocks. Pros and cons of those two options?
Old Nov 11, 2016 | 07:49 PM
Homer3D's Avatar
Homer3D
I guess it would really come down to cost.
The F55 shock simulators run about $200 for the set.
However, if you have a friend with a Tech2 (or dealer hookup), you might be able to get it tuned out cheap or free.
Personally, I would rather have it disabled in the computer versus using the simulators to trick the computer into thinking the F55 shocks are still there. But that’s just me.
Old Nov 11, 2016 | 08:15 PM
Midnight08's Avatar
Midnight08
Thanks for the info. As a practical matter, unless I was spending a lot more time on a track, I don't think the expense does enough to worry about, and as few miles as are on my car, it will be some years before I need a replacement.
Old Nov 17, 2016 | 08:37 PM
Travlee's Avatar
Travlee
these were just delivered, i got the poly bushings (which the GF will prob hate) but kinda confused on them... will prob make more sense on how they go in when i get the car up and disassembled
you might be able to help me with the bushings
To Shock Replacement
Old Nov 17, 2016 | 08:40 PM
Travlee's Avatar
Travlee
i have their heads on my car, wish they were closer.... but on the plus side, i have 21st century muscle cars locally, which is one of the lingenfelter kids shop
Old Nov 17, 2016 | 09:22 PM
Mordeth's Avatar
Mordeth
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I just did the DRM valved Bilsteins on my '07 Z06. Pretty straightforward.
You re-use the bracket off the stock shocks, but nothing else.
With the DRM Bilsteins, you will have a bag of 2 bushings, 2 washers and a nut with each shock in each box. You will also have 2 separate bags in one of the boxes with 8 poly bushings from DRM.
Set aside the 2 bushings that come in the Bilstein bag, you won't need them. The 8 bushings from DRM are of two varieties - 4 each. One has a female end and one has a male end. They "fit" together, so it is easy to tell them apart.
So for each shock, you need two of the poly bushings that fit together, two washers from the Bilstein bag and the nut.
For the rears: Take the rubber band off the end of the shock bolt. Then slide one of the washers on the bolt, with the "open" end (concave) facing towards the end of the bolt (up away from the boot). Then slide the male ended bushing up to the washer, with the smaller male part facing towards the end of the bolt (up). It will kind of fit inside of the washer. Then the bracket goes over the bolt. Then the female bushing and finally the last washer, this time with the female end "down" and the "concave" part of the washer down. Then you tighten the nut over the whole operation. You will need to hold the bolt in place with a hex to tighten the nut.
So the order is Washer-bushing-bracket-bushing-washer-nut. It should all fit together nice. The male bushing will slightly push through the bracket and fit into the female bushing. So with the rear shocks, you assemble the whole shock off the car, then bolt it back on.
With the front shocks, the bracket is basically the car, so you put the first washer and bushing on the shock, same as the rears, then install in the car. Then the top bushing and washer and nut are installed from inside the engine bay. Enjoy holding the bolt in place and tightening the nut inside the engine bay! Such a treat....
Old Nov 18, 2016 | 07:09 AM
Travlee's Avatar
Travlee
awesome, thanks so much for that explanation. it makes more sense now. i am going to try to get them on sometime next week
