About installing head/cam setup
http://www.westcoastcorvette.com/p-2...07-c6-ls2.aspx
Could you guys please give me some advices about which package will be better safe and performance for me, my first priority step is getting the safest package. I will also buy fast102 and fuel rail kit. I am not a driver like wot all the time
I am open all suggestions, thanks a lot.
If you're running the stock stall converter, you probably want to keep the overlap on the cam at or below 0 degrees. A wider lobe separation angle (LSA) and less duration will give you a better idle. Something with 218-224* duration on the intake, with another 4-8* on the exhaust and a ~114* LSA is usually a safe range for a stock converter on the LS2.
Your biggest challenge is going to be getting the tune sorted after the cam install, unless you have EFI Live or HP Tuners and can tune for yourself.
Your best bet is to contact a reputable shop that you've seen multiple good results from on this and other forums, and tell them what you want and ask them to put together a good package for you, with everything you need.
Good luck with your build. I know how difficult it can be trying to get the right parts when you're overseas.
I' ll choose at least less grind 230*duration + less 600*lift for sure ( like the level2 setup from the link I posted ), And I'll consult reputable shops either as you said, yeah It's really important bc of I am such a far distance from shops.. Probably I can change the converter for a better durable setup, yeah I' ll tune it again after the setup, thinking about 12.6-12.7 value at WOT for being safe... Thanks a lot
