Rear hatch button R&R
Old Nov 24, 2016 | 01:20 PM
TWS Racing's Avatar
TWS Racing
Default Rear hatch button R&R
NEVERMIND. FOUND ONE.
The outside rear hatch button on my 2008 ZO6 doesn't work. The one above the rear license plate.
Checked the fuses in the passenger foot well and they appear good.
Hatch will pop fine with the fob and with the dashboard switch.
I have read here that sometimes the button assembly gets corroded inside. I'd like to remove mine and check it. Is there a how-to write up on removing the switch? Didn't find one in a quick search.
Thanks!
Old Nov 24, 2016 | 02:06 PM
Dano523's Avatar
Dano523
Walk in the park.
Remove the inner passenger tail light, reach over and unclip the connector inside the fender cover, push the prongs in on the switch body, then push the switch outwards.
Note, wear long sleeve shirt, and take it easy since there a some sharp edges in the fender cover that can scratch you on the deeper side.
With the switch warm so the plastic is more pliable, pull the switch apart to give is parts a good electrical contact cleaner cleaning.
When you put the switch back together, use no lubes/keep all the parts bone dry instead. The switch will get dust in it over time, and any lubes just causes the switch to attract the dust just faster instead.
More detailed walk through and remember that you have to pull the lower part of the switch housing apart to get to the top contact points of the switch under the rubber button section.
https://www.corvetteforum.com/forums...-pictures.html
Old Nov 24, 2016 | 02:23 PM
RICH 28's Avatar
RICH 28
Here you go!
http://www.theredlion.us/C6%20Rear%2...n%20repair.pdf
Old Nov 24, 2016 | 03:47 PM
TWS Racing's Avatar
TWS Racing
Originally Posted by RICH 28
That's the one I found. Thanks!
I'm going to have to go deeper, per Dano523's post/thread link. I took the cover and button off and cleaned them to near perfection per that redlion link, and the switch still doesn't work.
I'll have to take her back out and completely disassemble to clean the contacts per Dano523's post.
Old Nov 24, 2016 | 11:39 PM
schizcat's Avatar
schizcat
Just buy a new one. I had the same issue. Took it apart once, it worked for a little while then quit. Took it apart again and still didnt work. Bought one from Henna and called it a day.
Old Nov 25, 2016 | 12:08 AM
cclive's Avatar
cclive
Just to make sure...you understand that the fob must be near the button in order for it to open the trunk, even if the car is unlocked????
Also, I put a small tab of tape over the keyhole to keep dirt out...easy to pull if I need to use the key.
Old Nov 25, 2016 | 12:14 AM
Dano523's Avatar
Dano523
Why buy a new switch over and over again every few years???
The switch is easy to pull apart, and is the copper section button on the bottom of the rubber section and the two contacts on the tip of the connector piece that just has to be cleaned instead.
Quick shot of contact cleaner and a Q-tip is all that is needed every few year to the actual contact areas of the switch, and about the same amount if time that a new switch is going to dust pack and would have to be replace if is was not just cleaned as well instead.
And if you want to know why the switch gets dirty/dust so quickly, as well the the back of the bumper cover and inside the bumper cover to, then just go to 1:20 of the below video. Hence nothing smooth about the air exiting from the under the car, and with the dead vertex of air, the back end of the vet actual slows the car down instead (increases the pressure wave on the air all the way back up to the front starting to flow across the car.
Old Nov 25, 2016 | 12:45 PM
TWS Racing's Avatar
TWS Racing
I already looked 'em up and have the link saved, but I figured it would be fun to see if I could get it working. Besides, want to play around with the cars while off work for Thanksgiving.
Old Nov 25, 2016 | 12:47 PM
TWS Racing's Avatar
TWS Racing
Haha. Yeah. Well aware. I have a few C6Z's. Good piece of advice on the keyhole. Thanks.
Old Nov 25, 2016 | 07:18 PM
cclive's Avatar
cclive
OK, good...just checking. And with the tape, I used electrical tape and just folded over the end a bit so that I can easily peel it back to use the key (really just to test the key once in a while) and then just stick the tab back down and it stays clean.
To Rear hatch button R&R
