New to LS9 engines...
Old Nov 25, 2016 | 09:15 PM
H8tulooze's Avatar
H8tulooze
Default New to LS9 engines...
What will it take to get my 2012 LS9 to about 800hp to the crank?
Thanks!!
Old Nov 26, 2016 | 05:16 AM
Brandon619's Avatar
Brandon619
I would start with the Lingenfelter 750 kit and add a good set of 1 7/8 or 2 inch headers with a solid tune will get you where you need power wise. You can piece together a 750 kit yourself for less money but the link provided gives you an idea on what parts you'll need. Hope this helps.
http://www.lingenfelter.com/product/...l#.WDlf0bU76aM
Old Nov 26, 2016 | 10:47 AM
H8tulooze's Avatar
H8tulooze
Thanks for the help!!!
Old Nov 26, 2016 | 01:36 PM
Dano523's Avatar
Dano523
Thanks!!
You looking for a just a Dyno number for a few pulls, or a engine that will be able to hold that 800hp used all day in and day out instead.
Just dyno number, then meth kit, spool the TVS-2300 up more with a smaller pulley, and Long tube headers will get you there quickly.
Hence the TVS-2300 spun up that much is going to become a heat pump, and the meth kit will help to cool it back down, and protect against engine knock/detonation.
If you looking for a motor that will be able to put out 800HP long term such as in road racing course use, the it's time to pull the bottom end to change out the pistons and piston rods to stronger units instead. Hence the stock pistons and rods will allow you to make 800 short term use, but when the motor is being pushed daily for that 800hp time and time again, the stock piston and rods will not last long instead.
Hell, there are guys with centrifugal force super chargers on stock LS-3 that are making that kind of power, but the motor is only making that every so often to allow the motor (piston and rods) to last isntead.
Old Nov 26, 2016 | 02:11 PM
H8tulooze's Avatar
H8tulooze
Sorry, I should have stated, this will be my weekend car, street cruiser.800hp at the crank, 700RWP or close to it with a 6speed.
Old Nov 26, 2016 | 02:42 PM
RicK T's Avatar
RicK T
Is this a Corvette or is the engine in another kind of car? Just asking for clarity.
Old Nov 27, 2016 | 01:02 AM
H8tulooze's Avatar
H8tulooze
Its going in my 1967 Nova SS
Old Nov 28, 2016 | 12:35 AM
H8tulooze's Avatar
H8tulooze
Well i got my motor, I want to change it to Wet sump, I saw they make a kit. Is there a diagram where all the connections plug, like vacuum, sensors, etc. Also do they make a aftermarket pulley set up chrome or polished? The stock one is ugly..lol
To New to LS9 engines...
