c6/c5 brake lines ques
Old Dec 4, 2016 | 09:13 PM
edean's Avatar
edean
Default c6/c5 brake lines ques
I just bought a set of wildwood from a member with a c5. My question is...will I need to change the brake lines or are the c5 and c6 brake line hardware interchangeable or will i need to get any adapter pieces?
Old Dec 5, 2016 | 08:26 AM
edean's Avatar
edean
Added pics. need to know if this is the correct fitting to connect to my base c6 hard brake line. they were on a c5 z06 before this.
Old Dec 5, 2016 | 01:09 PM
edean's Avatar
edean
wilwood is telling me the C6 has this fitting. Anyone know which one is used for the c6?
Old Dec 5, 2016 | 01:46 PM
bill.c6z06's Avatar
bill.c6z06
You'll need to change the lines and fittings. The chassis hard line on the C5 uses a bubble flare while the C6 line uses an inverted flare although both are 10 mm fittings. The correct Wilwood kit for the C6 is part number 220-9100. The kit for the C5 is 220-8176 which looks like what you have. Look them both up and you'll see the difference.
Old Dec 5, 2016 | 05:05 PM
Todd TCE's Avatar
Todd TCE
Supporting Vendor
That's correct.
C5 Bubble
C6 Inverted flare
If you are not sure what you are looking at: the hose shown appears to be bubble. It's single anglular seat.
Inverted flare has a small 'tit' inside the M10 thread.
*Note this image is the REVERSE showing the hardline end going into your adapters- you'll notice the indentation for the small tit to sit in it on the left image.
There is no way of knowing what the chassis adapter is that you link to. The fitting is in fact Metric based on the hash mark on the hex corners. But missing is the inside shape.
The Wilwood part number 220-6413 is IF for the C6. But the hoses you have will not fit the 3AN male end if that is your plan. The hoses shown are dedicated hoses crimped to the required factory hardline. You'll need 3AN female ends to pair with that small adapter.
Should you need them I have dedicated hoses for both C5 and C6 and the wilwood calipers, neither of which use chassis adapters. The hoses are dedicated like those in the first pic with used hoses.
__________________
TCE
Your one stop...for Wilwood Brakes!
480.967.7901
Old Dec 5, 2016 | 05:40 PM
timd38's Avatar
timd38
Easier to buy new braided lines.
To c6/c5 brake lines ques
