I have a 2007 coupe all interior lights work perfect except the cargo lights do not go off? They will go off after the 10 min but they do not. Go off with the other interior lights can someone help me with this problem?? Thanks kevin
Kevin,
The cargo area lights always have 12v on them, and are operated by the hatch pull down actuator which completes the circuit ground wire (White/Black).
You may want to check the latch release switch for the wiring, especially the ground wire.
