Poormans "LS7"
I'd like to grab some stock LS7 rods and an LS7 crank, run a forged piston in an LS2/LS3 block. The math makes sense, the only thing I can't find is aftermarket piston schematics to ensure there's proper pin placement. I'd also like to keep compression in the 11-11.5:1 range.
So on to the math
Crank 4" Stroke
Rods 6.064
Bore ~4.070 neighborhood
Deck height 9.240
Now assuming I cut a modest .010 the deck off any used block I buy, that leaves me with a piston that requires a compression height of ~1.165, which a quick search shows JE has, but I did not see any in a -5cc configuration, only domed.
So assuming the "shelf" pistons have the same pin placement as the stock LS7 piston, and if there's not, what is an acceptable deviation that would still allow for a reliable piston to rod configuration? And what other brands would have something in a valve relieved -4cc to -6cc configuration?
Careful going over 0.030 on the ls2/3 block sleeves they are weak and thin.
The pistons are out of the deck already by 3 to 6 thous so you may not want to deck block.
May I suggest something?
Sense you seen to know your way around machining why not use oem crank and ls3 rods and put you machining effort on the block and re sleeve it to 4.185 and use a solid roller cam on e85 and crank compression up to 13.5 or 14?
I'm not building this engine for all out power, I need it to pass smog in CA and the idea to use the LS7 parts allows me to dry sump at the same time. 500ftlbs is more than plenty for road course work.
If in the hole by .011 decking 15/.020 is fine with .051 compressed h/gaskets and makes easy to dial you compression of choice with a given piston.
So on to the math
Crank 4" Stroke
Rods 6.064
Deck height 9.240
My old track car (88 Mustang) would peak around 1.34g with R6's and I would like to best that with this car. It won't be every weekend, but when I do drive my cars, I push them to their engineering limit, if something is going to break, I will find it. This is basically a way to get a win/win with both setups, torque curve of the 4" stroke and dry sump.
This isn't really a "should I" inquiry, as a "can I" I need to know if wrist pin location on the LS3 piston is the same/similar as the LS7, or if there exists a piston with an acceptable wrist pin location for my proposed idea before going with a completely custom piston.
