Engine mounts to lower engine Z06
Old Dec 12, 2016 | 02:23 PM
pierrel's Avatar
pierrel
Default Engine mounts to lower engine Z06
Hi guys,
Due to excessive rubbing (actual grinding on the top) of my Fast 102 lsxr intake on the cowling i need to get my engine to sit lower in the bay.
Need advice on lower engine mounts. I know Hinson does 3/8", but does anyone do any lower than that? Urethane is preferred. Car is a weekend warrior / trackday car.
PFADT? Ive heard they lower the engine about 1 inch, is this true?
Thanks!
Old Dec 12, 2016 | 05:03 PM
timd38's Avatar
timd38
I have the Hinson with a FAST 102 in a base car and have zero issues with fitment.
Old Dec 13, 2016 | 08:30 AM
Unreal's Avatar
Unreal
Pfadts dont lower.
Hinsons work as advertised and drive nicely.
LG has billet ones but I believe they are stock height.
Old Dec 13, 2016 | 04:21 PM
MTPZ06's Avatar
MTPZ06
Originally Posted by Unreal
Pfadts dont lower.
I believe I saw in one of their latest posts that part of their revision to their new lighter design, they're slightly shorter to accommodate the various intake manifolds that cause cowl clearance issues.
Old Dec 13, 2016 | 04:41 PM
Unreal's Avatar
Unreal
You are correct.
Then again I would NEVER put solid mounts in a daily car. The pfadts are bad enough and they have a bushing.
Hinson all the way unless its a race car, then LGs.
Old Dec 13, 2016 | 04:46 PM
MTPZ06's Avatar
MTPZ06
You are correct.
Agreed...solid mounts on a daily, or even a seldom driven street car is just asking to create every rattle imaginable inside your car.
To Engine mounts to lower engine Z06
