WCCH heads
Old Dec 18, 2016 | 09:12 PM
PHM 06GTO's Avatar
PHM 06GTO
Default WCCH heads
I'm looking at a local C6 Z06 with WCCH stage 2 heads with cam specs .678 int/.680 exh with .239/.241 duration@114 degrees, with 15K miles on this set up. When or if should the valve train be inspected? Assuming it is running well with this mileage do you leave it or check it?
Old Dec 18, 2016 | 09:40 PM
Maligator's Avatar
Maligator
With those specs, id have them checked immediately. There was a forum member that had out of spec WCCH heads running a high lift cam
Old Dec 18, 2016 | 09:46 PM
Turbo2L's Avatar
Turbo2L
I would definitely have them checked.
Old Dec 19, 2016 | 10:59 AM
KW Baraka's Avatar
KW Baraka
Have a shop verify that the pushrod length is good-to-go.....and then swap out the springs for a dual spring set-up that's good to .700" lift.....like what's linked below:
http://www.racingsprings.com/RPM-Ser...prings/sku/168
KW
Old Dec 19, 2016 | 02:58 PM
JKLNHDE's Avatar
JKLNHDE
Theres no reason you need those cam specs in a street engine - ridiculous,
Old Dec 19, 2016 | 08:19 PM
outhouse's Avatar
outhouse
Now.
Past spring inspection with that specs. Generally mild cam springs get inspected/changed every 20k
Old Dec 21, 2016 | 11:59 PM
User Omega's Avatar
User Omega
My WCCH heads had 6k miles on them when I checked them out. Dual springs were 20lbs weak and guides were worn well beyond spec with less lift. .653"/.652"
Old Dec 22, 2016 | 07:17 AM
Maligator's Avatar
Maligator
wonderful, guess Katech was right about the guide material and the coating on the valves. Are your cam specs higher than any of Katech's cams? Why do you think your springs were weak?
Old Dec 22, 2016 | 08:17 AM
double06's Avatar
double06
I think the Katech K501 and the torquer cam on the exhaust side have lifts in the 650 area. The duration on the K501 is like 239 / 251 and the torque is like 220 / 244. Now the Katechs run less spring pressure with a single beehive I think. What was the spring pressure on the User Omega springs?
Old Dec 22, 2016 | 08:18 AM
double06's Avatar
double06
I think also Mr. Rocker arm is not happy once you get past 660 lift.
Old Dec 22, 2016 | 01:15 PM
User Omega's Avatar
User Omega
The cam was fairly mild. 231/246 653/652 115 +3
I cannot speak to why exactly springs loose pressure. That is probably a question better suited for someone who really knows their metallurgy.
I did not make those measurements. AHP checked them out while the heads were getting redone.
I would like to see the wipe on that for sure.
Old Dec 22, 2016 | 01:20 PM
User Omega's Avatar
User Omega
Lets just hope this moldstar90 guide material lives up to its name. In another 6-10k miles I will perform an on-car wiggle test to see if I feel like the heads need to come off for further inspect. I should have the car back together by the end of the month. Heads will be here tomorrow.
Old Dec 22, 2016 | 04:37 PM
Maligator's Avatar
Maligator
Post pics of the heads!!! Im thinking of dumping my WCCH and going with A.H over the winter
Old Dec 22, 2016 | 07:21 PM
User Omega's Avatar
User Omega
I will post some pics when they show up.
Old Dec 24, 2016 | 12:09 AM
User Omega's Avatar
User Omega
Delayed delivery until the 28th... Freaking giftmas..... The holiday truly has lost it's real purpose......
Old Dec 24, 2016 | 04:55 AM
American Heritage's Avatar
American Heritage
Supporting Vendor
You will be more than pleased with our Moldstar90 valve guides!!! We have seen noting but very positive long term results from our Moldstar90 valve guides!
Our Moldstar90 is the same material used in many F1 and Indy car heads.
Just checked the tacking for you and it looks like the heads are currently in Illinois and have an expected delivery date of 12/27.
Let us know if you need anything and thank you for your business!
http://www.americanheritageperformance.com/
Old Dec 24, 2016 | 09:17 AM
KM177122's Avatar
KM177122
Ya that cam is super aggressive for a street setup. I would put a more streetable cam in her. Like everyone else said, anything about .600 lift is too aggressive for the valvetrain.
Old Dec 24, 2016 | 05:26 PM
User Omega's Avatar
User Omega
I started a new thread so everyone could check them out.
https://www.corvetteforum.com/forums...post1593728271
To WCCH heads
