What is this?
Old Jan 26, 2017 | 04:47 PM
norton1090's Avatar
norton1090
Default What is this?
I found this on this forum somwhere and I lost it. Looking at the cold air/air intake block off, that appears to incorporate the factory set up into it and just seperates it off completely instead of just laying up front.
Looks like a good/inexpensive way to do a cold air on a GS.
Thanks for the help.
Old Jan 26, 2017 | 07:30 PM
Boomer111's Avatar
Boomer111
Gotta open up the bottom too to get cold air. This is blocking off the heat from the engine compartment, well at least in theory.
It looks like the Halltech beehive piece.
Old Jan 26, 2017 | 11:30 PM
norton1090's Avatar
norton1090
I did a poor job of phrasing this. My bad.
What type/brand of cold air intake is this CAI?
Old Jan 27, 2017 | 09:02 AM
CI GS's Avatar
CI GS
I haven't seen that air filter enclosure before, so it may be homemade. That's not the Halltech beehive though, although it works similarly. The Beehive rests on the radiator cover and encloses the whole area in front of the radiator shroud. It could be someone cut up a Beehive to make that though. As mentioned, to make use of this, you need to open up the shroud, or install something like a Vette Air scoop. Lots of folks complain that this causes surging, especially with the Halltech MF series air bridge, which moves the MAF forward. I have experienced that as well with a MF103, after seriously butchering the shroud, but the surge can be tuned out.
In fact, on one occasion when I experienced surging all of a sudden, all I did was tighten the clamps and pull the MAF and clean it with QD electrical cleaner and the surging went away.
Old Jan 27, 2017 | 09:22 AM
Kenny94945's Avatar
Kenny94945
Here's a bump.
FWIW I think I have seen that CAI for sale with some vendor before.
Almost looks like it will pass a visual smog inspection appearing OEM....well I can dream.
Good luck finding the answer.
Old Jan 27, 2017 | 11:28 AM
5knives's Avatar
5knives
It looks like a carbon fiber version of the stock LS7 air intake.
Old Jan 27, 2017 | 04:29 PM
MTPZ06's Avatar
MTPZ06
Shroud is made by a vendor. Here you go... https://www.corvetteforum.com/forums...e-shrouds.html
Old Jan 27, 2017 | 05:00 PM
Homer3D's Avatar
Homer3D
Looks like the stock intake that has been hydro dipped carbon fiber.
Old Jan 27, 2017 | 06:29 PM
xBoostx's Avatar
xBoostx
Cool idea wrapped in... farbon kiber?
Old Jan 27, 2017 | 08:19 PM
norton1090's Avatar
norton1090
That's the one.
Looks like it no longer exsist. But thanks for the help.
To What is this?
