I'm running Potenza RE050A Pole Position RFT on my '10 Grandsport. I know they are summer tires, but is there a minimum temperature that I can safely drive on these? I've been keeping it off the road when it's cold out (approaching 32F) but just wondering if I really have to? No snow or anything, pretty much dry road.
I think tim above is correct. Depending on the tire (and the road surface, the temp, etc.) it can be a little more like, 50 degrees being the cutoff point. But it really depends. I think it pays to be a little careful because an accident never makes a pre-announcement, even that the other guy's gonna cause it.
Note: Just found this in C6 Gen; you might like to note the comment below the pic in Post 3.
Thanks! Tried chatting with Bridgestone last night and they didn't have the info. They referred me to their tech line which is only open M-F.
Would really like to drive more in the winter, but don't want to give up summer traction and occasional track events. A second set of tires and rims is prob the answer but $$$.
I think the 45 degrees above is pretty close... I have had my extreme summer tires break loose in a turn at 40 degrees.. That scared the hell out of me enough that I don't take either of my Vettes out until the air is 50 degrees or above...I'm sure which tire "brand" your running has a lot to do with how they hold at a given temperature...WW
Drive it
I drive mine as long as the temp is above 30*. Under 40* you need to let the tires warm up, takes about 2-3 miles. (2013 GS, mich pss ZP)
I owned a C7 last year and there was a tire Cold/Warm dic display that told you when they were good to go.
It is not recommended that you drive the car near the 20* mark due to potential tire cracking. Haven't found an AS rf tire that fits the GS.
I've driven pilot super sports into the low 20's with no issue other than reduced traction. When it's cold pretend your driving on wet roads. When it's cold and wet, drive like it's snowing. I've never had and cracking or other tire damage.
Different tire brands will react differently in colder temps. I know when I was running the OEM GY F1 supercars, they were extremely dangerous below 45F, and on wet pavement at any temperature when the thread was half worn.
The Firestone WO Indy 500 tires that I replaced the GY's with, are great in wet conditions, and will also have good grip below 45F.
I'm on my 3rd set of Indy 500's and at 85K miles plus.
We do many long road trips, so I want a versatile summer tire, one that will work in the wet, and if the temperature drops, as in the Spring and Fall.
At Spring Mountain, I took their three day driving class the first week in December. Morning air temps were in the upper 20's F. when we got on track. I later asked the instructors how cold before they don't go out and they say they always go out no matter the temp, and that the Michelin tires have no problems as long as there is no frost on the track.
During the mornings, we couldn't get as much grip, about 10% less than we did during the afternoon when the air temps were about 60 degrees F. But we still were able to pull 1G in the long corners and that was while it was still below freezing.
