Brakes
Old Feb 5, 2017 | 03:45 PM
My505HP's Avatar
My505HP
Default Brakes
Wanting to upgrade my rotors and pads on my Z06.
Hawk vs carbotech
1 piece vs multi
ceramic vs carbon ferro-compound
It seems like with a two piece rotor you save on weight. Are there any down sides to a two piece rotor?
I drive my Z06 hard and race when the opportunity is there. I don't want the extra brake dust some of the performance pads have.
Old Feb 5, 2017 | 04:17 PM
timd38's Avatar
timd38
Can't help you with pads, I have Wilwoods, but 2 piece floating rotors help with even pad wear.
If you track the hard, you will want to get rid of those calipers because they are junk and get Stop Tech, Brembo or something much better than the 6 puck Z06 calipers from Australia.
Old Feb 7, 2017 | 01:21 PM
Todd TCE's Avatar
Todd TCE
Supporting Vendor
Pad brands are less important than compounds. Pick a brand and stick with them for a bit while you try various compounds. There's no one compound however that will prove to be ideal for all situations as they are formulated for specific uses. Moving from brand to brand can be a problem without new rotors or having the old rotors cut for proper bedding of the new brand. Most manufactures allow for swapping within the family without issue.
2pc hats and rotors, while lighter to the tune of 3-4lbs each, won't make better braking. The size and thus the torque remain the same. You can however get improved cooling from proper design and perhaps longer life vs the 1pc oe style. Don't let anyone kid you tho that they are more cost effective as you'll only replace "the ring"....given any 2pc will run you as much as 6X the $ amount (each, not including hardware) you better get that much or more life from it.
*Moving to a larger brake system (kit) with bigger rotors can push that into the good zone as larger rotors simply mean less wear and tear or a lower duty cycle vs the old size part.
The carbon rotor thing is great if you have money to burn. Or your car is a dedicated race car used for hours of extreme use. On the other hand...a good BBK will cost less and leave you hundreds if not a few thousand dollars to spend on seat time.
__________________
TCE
Your one stop...for Wilwood Brakes!
480.967.7901
Old Feb 7, 2017 | 07:37 PM
timd38's Avatar
timd38
I agree that you will not save money, but one thing that must also be considered is safety. Cheap rotors tend to explode at time and premium rotors tend to be far more durable and safer.
To Brakes
