T56 help T56 Gearset teeth counts
Old Feb 10, 2017 | 01:54 PM
n_brio's Avatar
n_brio
Default T56 help T56 Gearset teeth counts
I have a wihn in my gear box and i took it apart today and maby some one have change the gearing in the gearbox.
i have counter the teeth to this:
main counter
1 39 19
2 43 28
3 37 33
4 31 36 this is the input
it this right?
Old Feb 11, 2017 | 12:45 AM
Dano523's Avatar
Dano523
Close enough,
http://www.corvetteactioncenter.com/...008tr6060.html
And if you divide your gears to get final ratios, should be able to tell if you have a MM or MZ trans (if stock gearing of the two) or if the gears where change instead.
Also, below will point out which sets are what gears,
Old Feb 11, 2017 | 07:08 AM
n_brio's Avatar
n_brio
Did count wrong on the 3 gear now its right. but is the teeth count correct?
Old Feb 11, 2017 | 07:56 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
main counter
1 39 19
2 43 28
3 37 33
it this right?
You have a MM6 (2.66/1.78/1.30/1.00). Inspect your head gear (input shaft) and the gear thats on the very front of the countershaft. Look for scoring/over heating. If you had whine in all gears except for 4th gear, it's those 2 gears that has been overheated.
__________________
To T56 help T56 Gearset teeth counts
