Both of my cars are cammed. My C6Z will be vented aince itll be boosted. My camaro on the other hand is 100% NA, and is daily driven. Theres no catch can on there now since I just got the car cammed. Will doing a vented setup throw a cel/ car will run like **** since there will be a vac leak, or just get a sealed unit?
I got a vented can from Mighty Mouse. But it's not always venting to the open air. You'd have to talk to the experts at MM, but it only "vents" when there is too much pressure in the can. It's like a check valve I think (or a blow off valve). So, by design, it should never really vent unless something is wrong or there is just way too much pressure in the system.
You want to vent the crank case not the vacuum side of the engine. If you vent the catch can, vent it thru a top breather or route back to intake side. The small amount of vacuum on the intake side thru a small hose is enough to help pull a very small amount from the crank case when its not under pressure. When its under pressure it'll do its own venting, whether thro a small breather or back to the intake. Back to the intake is legal.
No reason to run a vented on either setup. MM cans are not vented unless you order them specifically that way. They do have a 1 way safety valve in case system over pressures then it releases to atmosphere, but that isn't a "vented" can.
Basically call/email dave and he can set you up with whatever you need.
It was a work in progress for a hot minute. The photos at beginning of the thread, I had the plumbing wrong. It took awhile, but I got the bugs worked out. It came together after some great feedback from forum members. By post #27 or so I had the bugs worked out.
Well all the catch can im going to get will be baffled.. juat wanted to see if doing a vented or sealed route would be prefered.
I see now. I miss read the question. This one I have is sealed. I would think that a vented Catch Can would leave a fine mist of oil on the entire engine bay. No-Go in my book.
With either, you want the intake side to put a vacuum on the valley cover side at less than WOT, to keep the oil cleaner a lot longer.
With a blower, since you will have higher than normal blow by at the pistons during WOT that is pressurizing the oil pan area way more than a N/A motor, here is where you want the extra pressure to be vented to the atmosphere via a check valve system , instead of being pushed back into the motor isntead.
Check valve has to be on the intake manifold side on an FI. When in boost, and the manifold transitions from vacuum to pressure, the check valve prevents boost bleedoff. You don't want a check valve on the crankcase side.
With a catch can on an FI, the intake manifold line gets checked back to the can, the crankcase gets a straight vent back to the can via a valve covered vent, and the crankcase vent back to the CAI with no check.
If you have no catch can on an FI then you're left with only the PCV U tube venting the crankcase into the intake. On an FI this needs to be checked, but you're checking the intake from reversing vacuum to pressure back into the crankcase. In this case, it is necessary to have a secondary CC vent (usually through the valve cover) BC at boost you have the worst of both worlds with CC pressure building and boost being checked at the PCV.
