Shifter/knob Question
Old Mar 14, 2017 | 09:16 AM
Malmond24's Avatar
Malmond24
Default Shifter/**** Question
So when I purchased my 05 recently, it came with the b&m ripper shifter and a black hurst ball ****. Now this shifter feels good, works wel, but.....
1. I hate the round ball over the stock c6 ****
And
2. The extreme notchiness between neutral and each gear.
Now I do make a handful of WOT quick shifts, and I've been told the aftermarket shifters are good at preventing you from causing to much damage. I've also read that you can slip a washer through a bolt on the back of transmission to help with the notchiness. You guys recommend that?
Is there a way to get the stock ball to work with this shifter?
Of course I'd like to try mgw or Hinson but reality is I have a working shifter and don't see the reason to spend so much on a new shifter when I could invest that money back into making it alittle faster.
Thanks for any input guys.
Old Mar 14, 2017 | 02:55 PM
Detroit1's Avatar
Detroit1
And
I did the RANGER MOD to my C5 Z06 . It helped some of the notchy feeling. I used just one brass washer. You can find post with pics.
I went from my C6 stock shifter to a Ball shifter and perfer that for the type of driving I do. For me the ball provided a shorter shift pattern, however I am not doing to many power shifts.
I had the B&M shifter and it allows you to install your stock shifter.
Hope this helps
JB
Old Mar 14, 2017 | 05:13 PM
Malmond24's Avatar
Malmond24
Hope this helps
JB
Stock ****?
To Shifter/knob Question
