2005 Steering wheel remove help pls
Old Mar 19, 2017 | 02:51 PM
FRANKENSTEIN4x42000's Avatar
FRANKENSTEIN4x42000
Default 2005 Steering wheel remove help pls
hi guys trying to take out my 2005 steering wheel, I know about the 4 holes in the back and I how to remove the 06 and up airbag but how do you release the springs on the 05? do I push straight back? is the spring similar to the 06 and up where I have to move it from left to right? help please.
Old Mar 19, 2017 | 11:26 PM
myredhead1's Avatar
myredhead1
I had two that were straight on and two that I had to get at an angle. Took me a day and a half until they finally popped out. There is no secret. Just stay at it.
Old Mar 20, 2017 | 12:00 PM
FRANKENSTEIN4x42000
Thanks I think the rear cover will get modified with my drill, since the steering wheel isn't worth anything it doesn't matter.
Old Mar 20, 2017 | 04:36 PM
schizcat's Avatar
schizcat
Its a pain but shouldnt take any longer than 5-10 minutes. The key -- when you hit 2 of the springs, do them on the same side. The airbag will slide out just a hair, dont let it slide back in. If I remember, I kept whatever I was using to pop the springs in the hole to hold it and used another tool to help on the other side. It takes a minute but you will see how its done.
Old Mar 20, 2017 | 04:57 PM
FRANKENSTEIN4x42000
THANKS, but which way to you push the springs?
To 2005 Steering wheel remove help pls
