HB Removal - PS help
Old Apr 6, 2017 | 07:59 PM
CMY SIX's Avatar
CMY SIX
Originally Posted by pmwinc
you are wrong 2x over.... 2 cam changes...wouldnt do it any other way. Lots of shops do it this way as well...
glad you said that, I would have been told I was rude for telling him he was wrong
Old Apr 7, 2017 | 01:25 AM
demon340's Avatar
demon340
Isn't it done by 1- loosening sway bar mounts, 2- loosen front cradle bolts, then rear a few turns, dropping the front of cradle down a inch or two, 3- remove return line and hi psi fitting from steering gear box, 4- remove bolts holding abs brake module, 5- remove shock, top A arm and slide the rack out the side. I'm sure i missed a few things, not sure if its easier to slide it out the pass side.
Old Apr 7, 2017 | 03:19 PM
719c6's Avatar
719c6
Done!!! Don't think I'll do this again... or shouldn't have to that is.
Thanks for all the help gentlemen!
