Exhaust Thoughts.
Old Apr 29, 2017 | 03:10 PM
carls2004's Avatar
carls2004
Default Exhaust Thoughts.
Was looking to possibly buy to put on my base 2006.. What else will i need.. Thanks
http://www.ebay.com/itm/06-07-08-COR...RY-kz8&vxp=mtr
Old Apr 29, 2017 | 06:23 PM
jrose7004's Avatar
jrose7004
https://www.corvetteforum.com/forums...n-exhaust.html
Old May 1, 2017 | 06:08 PM
BigBlok502's Avatar
BigBlok502
I put NPPs on my 2006, Z51 with 6spd manual. According to the ad, those are Bi-Mode mufflers from a Z06. Bi-Modes are only on the Z06 and ZR1 and have 3" over axle pipes. NPPs have 2 1/2" over axle pipes.
In order to put the Bi-Modes on your 2006 you will need a 3" to 2 1/2" reducer to mate to your X-Pipe (or H-Pipe). If you have an automatic, you may have clearance problems
NPPs from a 2008 are a direct fit. 2009 and up, the X-Pipe to over axle pipe has a different bend than the 2005 thru 2008 base models.
You will also need a vacuum source to operate the valves on the mufflers. I ran a vacuum hose form the unused nipple at the back of the intake manifold:
I also installed a vacuum solenoid so that I could open and close the valves at will. Others have installed the Mild to Wild kit.
To Exhaust Thoughts.
