Z06 Clutch replacement Recommendations
Old May 17, 2017 | 04:32 AM
GARY2004Z06's Avatar
GARY2004Z06
Originally Posted by NTMD8R
Well, I sort of was expecting it.
7 years ago, our C6 Z51 clutch packed it in (slave).
GM charged me $2800 to fix it.
Today our Z06 clutch failed... just like the Z51 did in 2010.
Pedal goes to the floor, or stays up, but does not engage clutch.
So, I have to fix it.
I was thinking of going with an after-market clutch.
But I have no idea which to go with (or stay with GM for that matter).
Of course, I'll replace the slave, and install an easy bleeder, and replace all the fluid.
So... recommendations, suggestions ????
Oh yeah, 600 flywheel HP, and we do serious autocrossing.
My RPS BC2 has served me well for years. The carbon friction surfaces make it a delight to drive on the street. (Taught my daughter to drive a manual trans using my car.) As for power level, my old setup made similar power to yours. I went with an aluminum flywheel which put the total weight at 25 lbs. The engine revved extremely quick. This is something you may wish to consider since you autocross.
