Sleeving a broken ls7 block?
Old May 15, 2017 | 01:27 AM
Chevytrk@72's Avatar
Chevytrk@72
3rd Gear
Default Sleeving a broken ls7 block?
Old May 15, 2017 | 07:50 AM
gilhuly's Avatar
gilhuly
good luck with that and welcome to the forums!
for better responses to your thread try posting here.......https://www.corvetteforum.com/forums...iscussion-100/
Old May 15, 2017 | 08:37 AM
FX VETTE's Avatar
FX VETTE
Ouch! Welcome to the CF!
Old May 15, 2017 | 11:17 AM
Moving this to C6 Tech.
Old May 15, 2017 | 11:27 AM
timd38's Avatar
timd38
Buy a block.
Old May 15, 2017 | 12:31 PM
4SUMERZ's Avatar
4SUMERZ
Have you tried to contact a local engine rebuilder to see if it can be resleeved? They may be able to steer you in the right direction, either it can be fixed, or a new block is the order of the day.
Old May 15, 2017 | 12:36 PM
Unreal's Avatar
Unreal
There is chunks of the block missing. That isn't a slightly cracked sleeve, that is a junk block. There is material massing that a new sleeve wont' replace.
Old May 15, 2017 | 07:54 PM
Chevytrk@72
3rd Gear
Default I am new member to this forum
[QUOTE=Unreal;1594742488]There is chunks of the block missing. That isn't a slightly cracked sleeve, that is a junk block. There is material massing that a new sleeve wont' replace.[/QUOTE
I appreciate everyone that tried to help on this thread.... i always like hearing from 2nds so on opinions.... i paid 500 dlls for the block and was wondering if then later we can put some darton sleeves...
Old May 15, 2017 | 07:58 PM
Unreal's Avatar
Unreal
Not with the missing aluminum chunks.
Steve @ RED would be the final answer, but I would bet money it is a big no. A crack at in the AL part means the block is junk.
Old May 16, 2017 | 01:13 AM
Chevytrk@72
3rd Gear
thank you for being honest it might be that i just threw away 5 bills....
To Sleeving a broken ls7 block?
